hp 840 g6 6050A3022501-MB-A01
    Re: hp 840 g6 6050A3022501-MB-A01
    Originally posted by kingkong computers View Post
    thankyou so much display ok but show errors on startup
    Need other EC file.
    Become a Badcaps supporter
    Thanks to all supporters.
      HI, i have a 6050A3022501-MB-A01 (850 g6), that will not power on and i want to try re flash bios as suggested in the forum.
      I have the CH341A programmer
      will this programmer work ?
      which bios should i use?
      do i need to re flash both bios chips ?
      should i take a backup ?
      which program recommended to use ?
      is there a general guide on how to backup and burn bios chip?
      I know it is a lot of question, and i want to thank you from advanced
        Always , always, always......
        if you are not sure about your backup file post it here and wait for an answer before acting because CH341A is a programmer with poor reliability.
          I need your help for unlock my bios HP 840 G6, I have the CH341A programmer and backup both chips (32mb and 16mb).
          A charitable soul can unlock them for me ?
          Many thanks in advance
            use RCUnlocher on the contents of the 16MB chip and then do what it says in the window ...
              Pleas remove startup error s
                Originally posted by gautes67 View Post
                hello everyone,
                i need your help for unlock my bios hp 840 g6, i have the ch341a programmer and backup both chips (32mb and 16mb).
                i unlocked your bios. Plz check and update
                  how did you get here ?? try this .. enter the bios and restore the security settings to the default values and restart the laptop..maybe it disappears from the errors ..
                    need help how cear this error hp endpoint security controller error
                      Check and Reply
                        hp elitbook 840 g6 bios password
                          pls clean me let dispaly problem and security error
                            Have you tried using RCUnlocker ?
                            You MUST:
                            https://www.badcaps.net/forum/showpo...42&postcount=4
                            Cleaning the ME firmware will fix the late display
                            https://www.badcaps.net/forum/showpo...41&postcount=3
                              You MUST:
                              yes i used rc unlocked and hp unlocked not work
                                i try me clean but not succedfull hear is file hp 840 g6
                                  Do not interfere with the original bios, just flash this file.
                                    Originally posted by Vesko356 View Post
                                    Try and leave feedback:
                                    display ok
                                      Originally posted by satishkumar View Post
                                      Check and Reply
                                      thankyou so much dear bios working ok but show some errors on startup
                                      plz check attachment
                                        use nbdmifit to close MPM, search for youtube videos how to do it . Most of the red error messages can be dealt with by using nbdmifit/HP Bios Config Utility . You do not need to ask for or flash another bios for those type of messages
                                        https://www.badcaps.net/forum/showpo...43&postcount=5
                                          Check and Reply
                                          after flash this file laptop screen touch not working plz help
