Need bios file for ASUS TUF Gaming FX505DY
    Hello to all
    everyone have bios bin for this gaming laptop
    Re: Need bios file for ASUS TUF Gaming FX505DY
    Post your bios backup .
      post the original bios here
        Here Sir I compress using rar files can you extract first.
          try..extras site Asus..
            Thanks, I'll try it later...
              i need bin file too
                Originally posted by jonnel View Post
                i need bin file too
                read post # 2,3
                  read post # 2,3
                  i have file with issue on and off in a second,,, after being update
                  can you help us
                    test
                      Plzz help after update bios hang on boot plzz build tnx..
                      Asus tuf fx505dy amd ryzen 5
                        try post #5..
                          try post #5..
                          not working, your bios is the newest
                            read post # 8
                              Originally posted by Repdata View Post
                              test
                              rev 2.1 work for me. thank's
                                I everyone, can you help me with this situation :
                                I have here an Asus FC505DY Amd Rizen that turns on but no image, the fans are in fulspeed, keyboard backligh on, light from the battery blinking and hdd to.
                                I made the basic tests, disconnecting wifi card, diferent rams, bios battery, hard reset, external video, and nothing, all the same.
                                I try to programm bios taken from here on a new bios chip but eventualy i didnt realize that the new bios chip i have here is 25L12873F witch operates at 3v and not at 1.8v as the original 25U12873F.
                                I tried to read the original bios chip with the 1.8v adapter in my EEEPROM programer witch is the TI866, until now i didnt have any problem with any bios chip, but strange thing is happen, i try to read the original bios chip and i cant manage to recognize, is the original bios chip protected?
                                Thank you very much.
                                  there is no way to be protected, you are wrong somewhere..
                                    Hi dear peste, than you for your reply
                                    I manage to read the original bios chip but strangly i cant read with the Check ID enable, do you know why ? because normally when this happens is bad connection on the socket or pins, but i clean it more than 1 time and gives me error all the time, the only way i can read is without checking ID :/
                                      ok read without checking..
                                        Thank you very much, kind sir! ASUS TUF Gaming FX505DY.308 AMD REV 2.0.rar worked for me
