THINKPAD L390 password
    Re: THINKPAD L390 password
    Originally posted by mp3boy View Post
    A couple of these L390 are failing to retain any changed BIOS settings 90% of the time. It also hangs for a moment when i switch through the BIOS menu tabs.
    I have reset the BIOS to defaults, pulled the CMOS battery and updated to latest Lenovo BIOS, but if I e.g. change boot mode or try to set a new supervisor password, most of the time it reverts back to previous settings.
    Has anyone seen this issue before, any suggestions please?
    Seems to be fixed by re-adding a supervisor password, save and reboot, then it keeps any changed settings.
      Originally posted by dycc View Post
      Try
      Thanks mate it worked
        Hello colleagues. I made two ThinkPad T13 autopathchers - everything was nice. Unfortunately, the L390 is not anymore. After processing the file, I can only hear one sound and a black screen. Could someone help me? Thank you in advance.
          Try
          Become a Badcaps supporter
          Thanks to all supporters.
            whats the io number of this board ?
              hello colleagues. I made two thinkpad t13 autopathchers - everything was nice. Unfortunately, the l390 is not anymore. After processing the file, i can only hear one sound and a black screen. Could someone help me? Thank you in advance.
              try
                Thank you. Everything works. You are great.
                  Dump from L390 20NR with svr pass. Can anyone help with it?
                    Tool for unlock. https://www.badcaps.net/forum/showthread.php?t=87588
                      BIOS from autopatcher doesn't work - black screen with beeps.
                        Tried once again (after reflashing original dump, booting, reading it again and patching again). Still the same issue.
                        Autopatcher does not reset NVRAM (it can't find the volume), maybe this is an issue?
                        Anyway, I thought this whole thread exists because autopatcher doesn't work...
                          Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                          Bump
                          Code:
                          Using UEFIReplace to inject 2 DXE drivers...
                          [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                          [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                          Looking for volumes to patch...
                          [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                             Not found... Skipping.
                          Done.
                          PATCH FILE: l390_2_1_PATCHED.bin
                          Good luck.
                          Laptop beeps some error code, no picture on screen.
                            try
                              That worked, thank you!
                                Hi
                                Please help. I got the Lenovo Thinkpad L390 (20NR0013UK) and bios is locked with supervisor password
                                I have downloaded Python and tried running the autopatcher cmd but all that happens is that a cmd window opens for a few seconds and then dissapears.
                                Am i doing something incorrect? Please help
                                  Hi, can you help me? I have a 20NS-S2U813 with supervisor password, can I dump and flash the bios with Windows? And if not, what is the bios chip? I have a RT809F programmer with clip, if needed. Thank you.
                                    Hi, I have an L390 i5 8th gen board with bios password (type 20NT / 20NU) and the same problem with black screen when using autopatch:
                                    I see @dycc had success patching - could you please patch the attached 2 dumps? Thank you!
                                      @pingaroon
                                      You can use a known working L390 patched BIOS file, but before doing so, make sure that you have a good backup of your BIOS, as you will use this Original BIOS at the last step of the unlock procedure.
                                        Ah yes, good thinking - will do that tomorrow. I am curious how the good patch file has been created though - could @dycc or anyone share?
                                        Originally posted by AAAC View Post
                                        @pingaroon
                                          try
