Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by jellytot View Post
    Looking for a firmware dump for a Toshiba 26EL933B. There is an update file
    on the toshiba site but requires a working tv to do the upgrade on. although its a Bin file and it looks ok at the beginning using HXD, but its about half the size..
    any ideas..? Thanks in advance..
    chasis,main,panel?
      Hi. dani502017. mainboard is: 32AV933_MAIN BD REV 1.02
      sticker info EU32AV933
      V1.00 P3
      WinbF544
      Slim Line TV. Can't see the Panel information its covered over by a Plate. would have to dismantle further.
        V1.00 P3
        WinbF544
        try
          dani502017! Your a gentleman and a scholar That worked like a charm.
          Thank you for your help
          Wow! you must have a great (large) library of files
          Thank you for your willingness to share.....
            I celebrated too fast! when I turned the set off it would not come back
            on same as original fault. Strange though when I reprogram the spi in situ it works again but when power is removed it wont come back on. the set appears fine when its running although the cpu is hot approx 72c I think its a cpu fault.or could it still be firmware ?.maybe just replace mainboard..any one seen this issue before ?
            Thanks for reading.
              Thanks for reading.
              Have you changed SPI memory too?
                Yes. I replaced the spi flash also tried reflowing the micro,also tried an upgrade using
                update file from Toshiba, still the same. each time if I reflash it works until power off
                  You better keep that programmer handy then!
                      Originally posted by Unspun01 View Post
                      Can anyone upload a firmware for an RCA 32" LED TV?
                      Model: RLED3216A (Canada)
                      Mainboard: CV318H-X
                      EEPROM type: Winbond 25Q16CVSIG
                      EEPROM Location: U10
                      Panel: AU T315XW06 V.6
                      May be same or similar to Proscan PLED3216A
                      Spectre 42 inch LCD TV
                      board on picture.
                      cv318h
                        Hi
                        I nead dump for Qadro 32af40
                        Tx
                          Sn032dld12at022-sm dump anolog modul uydusuz v.0.5
                          sunny dump file
                            I-JOY idi22spb 05 V2
                            pl dump HK-7050-CI-V4.1-B
                            .I-JOY idi22spb 05 V2
                              Re: I-JOY idi22spb 05 V2
                              Try original dump for eeprom+spi
                                I'm sorry but if you do not get details about TV, motherboard, panel, do not expect to get help.
                                It is valid for everyone.
                                  Hi someone have firmware for t.msd309.9b? Thanks
                                    thanks you
                                      MODEL: b32fa173bk
                                      PRODUCT CODE: BW32O173BBKPE421
                                      MAINBOARD: T.MSD309.9b 10345
                                      PANEL: LTA320AN12
                                      TUNER: XDTT-6F1C/T1146
                                        Hi someone have dump for Hisense 32h3e Main .Tp.ms3393.pb851
                                          Bravo led32 bed11 main-hk.t.rda8501p538 spi 25q32
                                          Bravo led32 bed11 main:hk.t.rda8501p538 spi 25q32
