17mb60-4 firmware
    17mb60-4 firmware
    Hello, I have a big thing to ask you, have a lcd tv, ALBA LED16911HD that has software problems, motherboard is Vestel 17mb60-4 I tried several versions of software toshiba, sharp, but the software image is negative, or divided into four parts, it seems that the problem is due to the 16inch display resolution, 720p, mounted on the tv, I'm interested in a firmware that contain rules bg dk UHF VHF VHL, thank you and please excuse my English, I use e Translate goo ...
    Re: 17mb60-4 firmware
      Please update your info and dont make your email public. firmware for unknown brands is always hard to find, i wish you luck in that.
        thank you for clarification, I complemented location, same motherboard uses the same 16-inch LED display and TELETECH 16912, Saba 1600jc , Telefunken TE16912B17, Vestel 16vh3021,and do not think that I am alone, all the best
          maybe someone knows a method for extracting functional software on a TV without the need to remove the flash memory on the motherboard, through RS232, JTAG, USB. all the best
            What kind of lcd panel is there in your set.
            CMO, AUO or LG ?
            No DVD ?
            There is a label on the rear with modelname
            and bar-codes.
            Obove the the codes there are numbers.
            Perhaps one with 18 numbers .
            There are no method for extracting the software
              no dvd,17MB60-4 100211 CPTWB11 CLA156WB11
                usb stick 17MB60 to cure Flashing Front LED fault which is now getting very common
                Could all members do this when they see one of these sets
                This is how to
                Plug empty USB Stick in to usb port (must be empty else will try coping file from stick into tv !!)
                Switch on set Access hidden Menu by
                Pressing MENU button then 7935
                select
                Copy NVRAM data
                You should get 2 to 7 bin files maybe more
                Please put these into zip file with a text file holding info
                Info need
                Make of set
                Model number
                Board number for instance 17mb60-1 or 17mb61 or 17mb70
                Screen type and part number
                Product Code on the back Label for instance 37654321
                If you get a working set saving this will help otheres with Flashing Front LED fault
                To save a set to your tv copy correct file to usb stick plug into turn tv on via mains while holding down ok button on remote
                Remember Data is unique per Model
                  vestel tech note for mb70
                  so works on mb60 mb61 and mb70
                  also note this need P+ button instead of ok button on remote
                  so best to try both if trying to upload file
                  if OK button not work try again with P+ button
                    iuliantv@yahoo.com
                    please up load firmwares you have in zip file with extra info
                    Info need
                    Make of set
                    Model number
                      Does anyone have 17mb70-5p firmware for sharp Lc40LE511E. I have got it to boot but doesn't recognise remote or touch panel.
                      Had to heat cpu to get boot would a reflow cure the remote problem
                        https://www.arizanotlari.com/2019/03...71-17mb75.html
                        https://www.badcaps.net
                          arizanotlari: I just visited your Site. Very helpful information
                          Thank you for your work..
                            Hi arizanotlari. I have a JVC LT-40C860 uhd led tv Mainboard 17MB120 It is in a
                            boot cycle and I think the nand is corrupt the JVC logo comes on in a constant loop. I have searched the net but cant find the software files to restore as explained in the 17MB120 chassis pdf.
                            1. mb120_en.bin, RomBoot.bin, PM51.bin and usb_auto_update_G6F.txt documents should be copied directly
                            inside of a flash memory (not in a folder).
                            2. Insert flash memory to the TV when TV is powered off.
                            3. While pushing the OK button in remote control, power on and wait. TV will power-up itself.
                            4. If First Time Installation screen comes, it means software update procedure is successful.
                            Any thoughts? If I could get a nand dump It might work also
                              Hello.
                              for rewrite nandflash you need programmer.
                              for usb upgrade : https://yadi.sk/d/YY_0QmW3sezsDg
                              sorry my english
