Hello, I have a big thing to ask you, have a lcd tv, ALBA LED16911HD that has software problems, motherboard is Vestel 17mb60-4 I tried several versions of software toshiba, sharp, but the software image is negative, or divided into four parts, it seems that the problem is due to the 16inch display resolution, 720p, mounted on the tv, I'm interested in a firmware that contain rules bg dk UHF VHF VHL, thank you and please excuse my English, I use e Translate goo ...
17mb60-4 firmware
Re: 17mb60-4 firmware
thank you for clarification, I complemented location, same motherboard uses the same 16-inch LED display and TELETECH 16912, Saba 1600jc , Telefunken TE16912B17, Vestel 16vh3021,and do not think that I am alone, all the bestLast edited by iuliantv; 10-03-2014, 11:20 AM.
usb stick 17MB60 to cure Flashing Front LED fault which is now getting very common
Could all members do this when they see one of these sets
This is how to
Plug empty USB Stick in to usb port (must be empty else will try coping file from stick into tv !!)
Switch on set Access hidden Menu by
Pressing MENU button then 7935
select
Copy NVRAM data
You should get 2 to 7 bin files maybe more
Please put these into zip file with a text file holding info
Info need
Make of set
Model number
Board number for instance 17mb60-1 or 17mb61 or 17mb70
Screen type and part number
Product Code on the back Label for instance 37654321
If you get a working set saving this will help otheres with Flashing Front LED fault
To save a set to your tv copy correct file to usb stick plug into turn tv on via mains while holding down ok button on remote
Remember Data is unique per Model
vestel tech note for mb70
so works on mb60 mb61 and mb70
also note this need P+ button instead of ok button on remote
so best to try both if trying to upload file
if OK button not work try again with P+ buttonAttached FilesLast edited by FIXITNOW; 11-04-2014, 05:59 AM.
Originally posted by iuliantv View PostHello, I have a big thing to ask you, have a lcd tv, ALBA LED16911HD that has software problems, motherboard is Vestel 17mb60-4 I tried several versions of software toshiba, sharp, but the software image is negative, or divided into four parts, it seems that the problem is due to the 16inch display resolution, 720p, mounted on the tv, I'm interested in a firmware that contain rules bg dk UHF VHF VHL, thank you and please excuse my English, I use e Translate goo ...
iuliantv@yahoo.com
Info need
Make of set
Model number
Originally posted by arizanotlari View Post
Thank you for your work..
Hi arizanotlari. I have a JVC LT-40C860 uhd led tv Mainboard 17MB120 It is in a
boot cycle and I think the nand is corrupt the JVC logo comes on in a constant loop. I have searched the net but cant find the software files to restore as explained in the 17MB120 chassis pdf.
1. mb120_en.bin, RomBoot.bin, PM51.bin and usb_auto_update_G6F.txt documents should be copied directly
inside of a flash memory (not in a folder).
2. Insert flash memory to the TV when TV is powered off.
3. While pushing the OK button in remote control, power on and wait. TV will power-up itself.
4. If First Time Installation screen comes, it means software update procedure is successful.
Any thoughts? If I could get a nand dump It might work also
Hello.
for rewrite nandflash you need programmer.
for usb upgrade : https://yadi.sk/d/YY_0QmW3sezsDg
sorry my englishhttps://www.badcaps.net
