Dell Inspiron 620/Vostro 260 wont start if left plugged in.
    Hello
    I just repaired a Dell Inspiron 620 by replacing the motherboard. I would like to see if I could repair the original board for another project.
    The model of the motherboard is GDG8Y.
    The problem with it was if left plugged in the PC would not power on. I could unplug the PC for a few minutes then plug it back in and it would usually power on, however i would have to hold the power button in for 5 sec or so.
    After testing the PSU and power button (tested good) I determined the motherboard was likely bad.
    I googled the problem and found several posts where people had the same problem and the fix seemed to be to unplug the front panel USB and audio cables. I tried that and it didn't work in my case.
    Do you think the problem is fixable on the component level like a bad cap (none with obvious signs of popping), resistor, voltage regulator, etc?
    Any help would be appreciated.
    thanks
