I have just seen this question asked on another forum so thought i would post it here too as we are seeing nand issues too so whats you thoughts regarding this.
I figured out many LCDs using Vestel-based boards with "only blinking LEDs" have worn out NAND flash chips. If power supply is working well (no capacitor problem) NAND flash is main problem. I unsoldered NAND128W3A from Vestel 17MB70 which normally should have 16MB capacity but when reading it with a NAND programmer it shows nearly 5MB bad blocks! Some mainboards do have one big NAND, some do have two (one big and one small)...
My question is: Has anybody tried to swap faulty NAND with a brand new (empty) flash and tried a firmware update via USB? Is that possible or is bootloader which starts USB update located in NAND, too so that using a new (empty) flash update cannot start? Because of it is TSOP48 package I do not want to try without need....
