Re: How to replace nec/tokin OE128 in laptop motherboard?
use the one from Bestsheng Elecronics.. its has 350uf value with low ESR 0.024.. the other black caps has only 315uf with ESR 0.025..
put 4x350uf ESR 0.024
You want under 10mOhm ESR ideally. Like I said you're best recycling the 4 tantalum caps nearest the CPU on a dead board, they serve exactly the same function. Random caps found elsewhere on the board are almost definitely too high ESR.
How u find these charactrs of a caps by seeing its pic, but there is no writen esr and voltage? Im new in electrnics.
Plz detil me.
Plz detil me.
This may be more the answer you want
Ok You posted the picture
if you move the mouse over the image or copy the link from the picture http://i01.i.aliimg.com/wsphoto/v0/1...pg_200x200.jpg
and paste it into notepad you will see among other things the part number 2R5TPE330M9 and the voltage 2.5v
If you copy the part number and paste it into google the first listed item I get is the electronics retailer digikey.
Click on that and you will see all the details of the item and also a link to a full datasheet for it. http://www.digikey.com/product-detai...art_dkc_buynow
You can find details of most electronic components if you google the part number followed by datasheet.
Hard part is understanding them
In this case the member who answered you may simply have an understanding of the part numbering as you can see it contains the info 2R5 Must be the voltage TPE is the series 330 is the uf and M9 is the ESR
Actually I thought he may have mis typed when he said 350uf value with low ESR 0.024 as it is clearly labelled 330 but see his esr meter may not be accurate? though 350 may be within tolerance.
I hardly found 6 caps of 220uf and there is written word 'g' near the digits 220. Means, these are of 4vdc. Can i use these caps instead of 4*330uf. If yes, how many caps of 220uf and 4v i use?
I will upload pictures of it.
I upload its picture.
