Need help with Dell Inspiron 15 5558 backlight.
    Had a computer my new tech was replacing a broken lcd screen on. Idiot didn't remove the battery like I told him to and fried something on the board. I'm very good at de-soldering and soldering but I have no clue what to replace. Can anyone help direct me to find out what I need to replace to fix this issue?
    I tried plugging in the original monitor which worked, just had a giant crack going down the screen and of course that one did not work either.
    Thanks for your time.
    Re: Need help with Dell Inspiron 15 5558 backlight.
    Have you checked the fuse just under and to the right of screen connector, p1524 is marked on it
      check for lcd_vdd voltage as well.
      sigpic
        i need schematic la-b843p dell 5558 urgent plz.
          I NEED la-b843p dell 5558 BIOS PLZ
            I also need dell inspiron 15 5558 BIOS please
              Dell Inspiron 15 5558 BIOS ROM file
              i need dell inspiron 15 5558 BIOS ROM file , can't extract ROM file from dell site BIOS
                Here is the bios have not tested please let me know if it works.
                  test external display is ok on not
                    Check the lcd backlight secuit if all voltage is complete it should be fuse 19v on charger 3v and 3v for signal
                      This BIOS working properly for inspiron 15 - 5558 , Thanks "cyberhack"
                        i need la-b843p schematic diagram please any one send
                        thanks
                            anyone here have EC file for this motherboard?
                            LA-b483p my chip is only 4mb capacity
                            thanks if someone can provide .. this is the original file
                              thank u
                                any one solution
                                  i need la-b843p schematic dell 15-5558
                                    Here is.
                                      Originally posted by imranromi View Post
                                      Here is.
                                        Here is.
                                        Thank you for that schematic digram
