Dell Vostro 1510 display issues
    Friend's machine. I have board-level repair skills he doesn't.
    Machine fell from a 5 ft shelf to a tile floor. No visible signs of damage other than a small crack in the upper right corner the bezel.
    Display output to an external monitor is perfect.
    Display to LCD is as follows: multiple vertical lines spread across the screen allowing some of the actual display to show but a bit muted AND at specific intervals the screen flickers horizontally as if it were an old TV set with horizontal hold issues.
    Re: Dell Vostro 1510 display issues
    Try another display (internal) and/or lvds cable.
      Try another lcd screen
        hp g6-1c74ca Bios dump Required... help..
          thanks
            This thread is closed. I received the correct answer in another category.
              Hi. I need Dell vostro 1510 PP36X bios
