Alienware M14x R2 with 7 beeps error
    Hi, I have an M14x R2 with 7 beeps error, when I boot it I get the 7 beeps and the speaker sounds like it doesn't have much power, only some of the keyboard lights light up, and change colours as well as dim each time a beep sounds, would there be some kind of power issue? Thanks
    Re: Alienware M14x R2 with 7 beeps error
    7 beeps mean CPU error.
    try another CPU if it is not soldered on the board.
    does it display any picture on the screen?
      Thanks for your reply, I don't have another CPU to try but it is unlikely to be the CPU as 7 beeps also means another issue with the motherboard.
        that is right. it may be the board.
        does it display anything on the screen?
        after turning on, measure voltage on PL502.
          One thing I've missed is it is missing the LCD ribbon cable as the previous owner sent it to a repair shop and they must have broken it, it doesn't display via VGA nor HDMI, does it require the LCD to be connented to complete post, I've used other laptops without a display connected before via VGA.
            connecting to an external monitor is good too.
              It doesn't display via VGA nor HDMI, where is PL502 located?
                if PL502 is not written on the board, probably I looked at a wrong schematics file.
                please upload the schematics file of the motherboard, so we can help you.
                or report the board ID.
                  My board is "LA-8381P", is this the correct one:https://cdn.badcaps-static.com/pdfs/...509ff903a8.pdf
                    this is the right schematics.
                    so after turning on, measure voltage on PL704.
                      I'm a novice at this, what side of the board is it on?
                        it depends on your board.
                        you have to search all the board to find a coil labeled PL704.
                          How do I read a coil with the digital multimeter?
                            Do I put the leads on each side and does it have polarity?
                              PL704 shows 0.9mV
                              PL705 shows 0.9mV
                              PL703 shows 0.9mV
                                so it does not have CPU_Vcore. thus, the CPU may be fine.
                                now measure voltage on other coils including PL202, PL303, PL403 , PL504 , PL604.
                                it takes time to reach a conclusion.
                                  PL202 - 3.325V
                                  PL303 - 0.5mV
                                  PL403 - 0.3mV
                                  PL504 - 0V
                                  PL604 - 0V
                                    that is strange. there should be some voltage.
                                    now check voltage on pin8 of U48 and pins 95,104,107 of KB930 after turning on.
                                      What page is U48 and KB930 on?
                                        PDF has a search tool you can find any text in the file.
                                        page 14 and 47.
