Alienware M14x R2 with 7 beeps error
    Re: Alienware M14x R2 with 7 beeps error
    Originally posted by caspian View Post
    PDF has a search tool you can find any text in the file.
    page 14 and 47.
    pin 8 U48 - 3.319V
    Still looking for KB930 on the board
      that is strange. there should be some voltage.
      now check voltage on pin8 of U48 and pins 95,104,107 of KB930 after turning on.
      pin 8 U48 - 3.319V
      KB930
      pin 95 - 3.289V
      pin 104 - 3.290V
      pin 107 - 3.291V
        KB930 is written on the IC, not beside it.
          Results in previous post :-)
            now go to page55 and measure voltage on pins 2,5,6,10 of PU303 after turning on.
            report if you observe a temporary voltage on PL303 just after turning on.
              Ether I've done this wrong or it's very odd
              PU303 is very small and unsure if they're the correct pins
              pin 2 - 3.322V
              pin 5 - 155.5mV and keeps riseing/fluctuating
              pin 6 - 3.322V
              pin 10 - 0.1mV
              PL303 - first on 0.8mV
              0.5mV
              0.3mV
              0.1mV
              0.3mV
              0.1mV
                Is this correct?
                  Originally posted by Johndill View Post
                  Is this correct?
                  no pins are not ordered like this on any IC.
                    I corrected the pin numbers.
                      PU303
                      pin 2 - 1.497V
                      pin 5 - 3.287V
                      pin 6 - 0.604V
                      pin 10 - 3.320V
                        there is voltage on one side of PL303 but the other side has no voltage.
                        check resistance on pin2 of PL303 relative to GND.
                          PL303 has no continuity, how do I check resistance?
                            black probe on pin1 and red probe on pin2 of PL303.
                            put the multimeter on resistance mode.
                              I tried again and it gets continuity, resistance juggles from 0.2 to 0.1, tried voltage again and it's 1.497V, I must have done it wrong
                                so it is fine. then why are voltages different on the two sides of PL303?
                                now black probe on pin1 and red probe on pin2 of PL303. then after turning on, measure voltage.
                                  resistance juggles from 0.2 to 0.0, voltage is 1.497V on each side, I don't think it was making propper contace before, I gently scraped each side to clean the contacts
                                    so there is a voltage there.
                                    now measure voltage on PL403,PL504,PL604 again.
                                    probably some of them were measured before by mistake.
                                      Now measure voltage on pl403,pl504,pl604 again.
                                      Probably some of them were measured before by mistake.
                                      pl403 - 1.8v
                                      pl504 - 0v
                                      pl604 - 0v
                                        Thank you heaps for all your help so far, I'm heading off to bed as it's very late here in Australia, I'll give your next suggestions a try in the morning :-) Thanks
                                          Please buy and fit a new LCD cable first. Many Dell and Alienware (since it is owned by Dell) models will NOT boot up unless the LCD cable is correctly fitted and the screen is okay. Some models even got a specific beep code for that.
                                          A working TV? How boring!
