Daytek F19AH this unite powers on with green light and fades to orange when not connected to computer. The back lights will not light. Changed all caps except one a 10uf@50v.. Checked the voltages as follows; across large capacitor 169v. from gr to red to the logic board 11.98v across Q13 and 14 11.98 v 9.6 v dc on T1 from center to either leg. The resistance on T101 black to white wire in infinite. Not sure what these readings meen if any thing? From what I can read this would indicate that the ac and dc is working?? Any suggestions
Daytek F19AH
Re: Daytek F19AH
What does it do when it's hooked up to a known good video source (might be good to check all available input types - D-sub, component, DVI, HDMI, etc.)?
Originally posted by davgChanged all caps except one a 10uf@50v.
The voltages to the logic card sound fine; have you measured the voltage to the inverter? Pictures of the logic card and inverter may yield more clues.
Re: Daytek F19AH
Thanks Wrog for your post. When connected to the computer the light stays green. I didn't replace the small cap next to the big one because I didn't have a suitable replacement. Not sure where to measure the voltage to the inverter. I will post a picture of the logic board in the morning.
Re: Daytek F19AH
Originally posted by davgThanks Wrog for your post. When connected to the computer the light stays green. I didn't replace the small cap next to the big one because I didn't have a suitable replacement. Not sure where to measure the voltage to the inverter. I will post a picture of the logic board in the morning.
What are the markings on IC101 (rear side, upper center), and Q13 and Q14 (rear side, center)? Find the data sheet on IC101 and make sure the output voltage is within range, and check Q13/Q14 for shorts. Also, what are the markings on IC1 and IC4 (rear side, right)?
Re: Daytek F19AH
Originally posted by WrogI should pay better attention (I think I hear PB sighing somewhere); the power and inverter boards are combined.
IC1 markings look like 129932GN top 0505A center and 13096601T bottom and on IC4 393 top E450 bottom. I have no idea where to find data sheets for these componets? I have not tested the Q13/Q14 yet still have to do some reading on testing transistors in circuit.
Re: Daytek F19AH
Wondering if anything ever came of this thread/monitor? I have the same monitor but it is a F19DH...SAME POWER BOARD though. It will not power up at all. No power light or anything. Opened it and there was one bulged 470uf 25v cap. I replaced that along with the other 470uf as well as both 220uf and the 100uf but they are all 50v now. The only two I did not change were the 10uf 50v or the big filter cap beside it as I didn't have those. Still no power light or anything. Before I replaced the caps I noticed there was a steady clicking noise coming from the board when plugged in and the clicking still remains after replacing all the caps. Using one of those stethascope things for finding engine noise (it works) and I find the noise to be coming from the yellow transformer beside the large filter cap. Is that transformer supposed to make a steady but very quiet clicking noise or is that the next thing to replace? (In the first picture the big black cap behind the blue 470uf is the original one that was bulged and the first one I tried replacing. It was identical to the blue 470 thats in the pic. There were two of them.)
Re: Daytek F19AH
Originally posted by UserName666 View PostThe only two I did not change were the 10uf 50v or the big filter cap beside it as I didn't have those.
The SMPS is clicking as it tries to startup.
I suggest replacing that little cap and retesting.--- begin sig file ---
--- end sig file ---
Re: Daytek F19AH
Originally posted by UserName666 View PostOK I somehow passed these before but I found two 10u-M 63 volt caps. What is 10u-M?? Will these work. The other just say 10u. Not 10u-M or 10uf.
If they measure 10uF, you can use them as a test to see if the SMPS starts up, but I would use a quality cap longer term.--- begin sig file ---
Re: Daytek F19AH
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Re: Daytek F19AH
I only have a digital meter and not sure how to do cap checks with it but tried the one labeled as 10u as I have never heard capacitors in anything but farads and was pretty much the same physical size/values +13 volts. Not gonna mess with the one that says u-M though.
The transformer still clicks like before any of the caps were changed. Only one left is the big filter cap which I know I do not have so will have to do some hunting now.
Re: Daytek F19AH
Originally posted by UserName666 View PostI only have a digital meter
If those are absent, see if you get 1.4 *main DC voltage across the main filter capacitor.--- begin sig file ---
Re: Daytek F19AH
Sorry but Im not following that. This is the first time I have tried something like this and with doing it live. What I did was test at the secondary of the clicking transformer and thats 0 volts. Across the filter cap fluctuated from 158v to 162 volts on the DC setting. My filter cap is 120uf 400v.
Re: Daytek F19AH
Originally posted by UserName666 View PostSorry but Im not following that. This is the first time I have tried something like this and with doing it live. What I did was test at the secondary of the clicking transformer and thats 0 volts. Across the filter cap fluctuated from 158v to 162 volts on the DC setting. My filter cap is 120uf 400v.
Re: Daytek F19AH
You were asked to check for 5 and 12 volt output. Looking at your second photo, next to to the large yellow transformer and between the heatsinks looks like a 6 prong plug. Look to see if any of those prongs are labelled 5V, 12V, ground, etc. With your meter set to DC and both boards and backlights connected, power on the monitor and check for the 5V and 12V voltages. I suspect you'll read 0 volts, since the transformer secondary is putting out 0V.Last edited by jetadm123; 08-30-2010, 10:16 PM.
Re: Daytek F19AH
Wondering what the significance of 1.4 is or where it comes from?? Trying to learn something as I go here and not just play musical chairs with the components lol
As for the 6 pin connector it is indeed 0 volts. - lead on middle top gnd pin and + across all others 0 volts. Same with the middle bottom gnd pin. That was tested with live power. (Transformer still clicking)
Diode test WITHOUT live power and Diodes still in the board. DMM set to diode.
Blue (By filter cap) - .491v Reverse leads = 0v
Red (By transformer) - .491v Reverse leads = 1.643v
Re: Daytek F19AH
Originally posted by UserName666 View PostFrom post #36 in the BENQ T905 post regarding diodes:
"Test them with your diode setting. One way should measure 0.4 to 0.7V. Reserve and the other way should measure "1" or 0L."
So would that mean that the diode giving me a reading of 1.643v is damaged??Friends don't let friends buy Samsung ....
