Strange behavior on the proline laptop
    Hello my lovely brothers
    I'm facing a strange behavior here, the laptop comes up and quickly shut down.
    When i remove the ram it cones on and the green light stays and doesn't shut down, I changed the ram and inserted another ram it still doing the same thing.
    I checked the ram power supply there is no short to ground
    Measurements are:
    -Ram power supply = 1.5v
    -Cpu power supply = 0.0v
    Motherboard number it = 6-71-W24Z0-D02A I dont have the schematic
    Re: Strange behavior on the proline laptop
    Schematic. https://drive.google.com/file/d/1mdu...uNfbbodo-/view
    Bios. https://repo.palkeo.com/clevo-mirror/W2xCZ/
      Thank you so much brother i will update you all if I managed to solve this
        Hello guys please clue me up here on this machine, here my finds so far
        I Have 1.11v on the vcore, and the gate on one of the mosfets for vcore power supply is 0.007 when compared to ground.
        One more thing i have 0v on the gfx core
        The laptop keeps on turning On and quickly shuts down after pressing the power button
        Any clue guys, why the value of the gate is so low if compared to ground? Is this normal
          The switching on those fets is really fast and your meter probably isn't picking it up correctly. Get a scope if you have one and look at it.
          0v on gfx core is most likely your problem. Whats the resistance of gfx core to gnd?
            It 004 using continuity mode
              Resistance please.
                Resistance please.
                How?
                What range should i set on my multimeter please help
                  How?
                  200 ohms
                    Originally posted by mcplslg123 View Post
                    200 ohms
                    It 04.8
                      It 04.8
                      Thats fine.
                      What do you get on Pin 4 (VR_EN) of PU1?
                      Please measure while powering the board. It should go high when the board turns on.
                        Thats fine.
                        Yes i did, i get 3.25v
                        The board is still doing the same thing, powers on and quickly goes off
                        I checked all the power supplies, they are all okay, 5v is okay, ram volts is okay i have 1.5v on the ram chip and coil, pch power supply is okay .
                        If i remove the ram it powers on and never shut down but obvious no display and doesn't post
                          Can i have the list of things to check so that in feature i will know what to check guys and give you proper information.
                            Now check
                            Gate & Drain voltage on PQ108, PQ109
                            Gate voltage on PQ110, PQ111
                            There is no universal guide for troubleshooting something. But usually you always check all power rails before doing anything else. That will give you a clue of what is going on.
                            Power rail missing? => Fix it.
                            All power rails present and everything should be ok but no post? => Bios or dead CPU
                              Going by my experience, your sio chip is bad. Replacing it will solve your problem.
                                Thank you i have to find the chip and update you
                                  Now check
                                  All gates have 0V of PQ110, PQ111, PQ108,PQ109 i have 0v on their gates, the Switching mosfets do receive 19v but they don't switch, they are not being told to switch
