Samsung UN60H6203AF LED TV Screen Won't Turn On
    Re: Samsung UN60H6203AF LED TV Screen Won't Turn On
    The LED driver IC should be SMD located on the bottom side of the board.
    I thought that was on the top. When i look at the bottom the smd points to that part. I figured the driver would be attached to gate so im not sure what part is which. I took pics of the area hoping that helps.
      Are these good enough pics budm?
        I cannot read the P/N on top of the IC.
        Can you clean the top of the IC with Alcohol to see if you can read the prints?
        https://www.badcaps.net/forum/attach...9&d=1602949370
          Best i can tell it is 4077014k2620. The 0's could be 6 or 8 instead. And my eyes tell me that could be a k or a x, but i think what i have is correct. Consequently, the only magnifying glass i had fell onto the concrete right out of the lens as i was looking at the part.
            Do those numbers seem right? I cant find anything online with that part number.
              I cannot find anything at all either.
                I will get one of my kids to look at it out in the daylight tomorrow to see of they can see it better. Never thought I would have to say that but here i am in life lol.
                I really appreciate your help so far. I am so ready to get this tv out of my way and on the wall.
                  Looks like: 407 7014X 2620
                  I've modified (contrast, exposure, shadow) the original picture to make it a little easier to see.
                  Here's a previous thread trying to identify a 7014x SOIC-8 LED driver...
                  https://www.badcaps.net/forum/showthread.php?t=82041
                    Confirmed by younger eyes the number is 4077014x2620 (after i explained she was not looking at "plans for a golf course", but electrical traces instead).
                      Perfect! Thank u. That is what i see as well but urs is much clearer. Now, i only get a mathematical equation when i plug that in to the google.
                        Now that we have the part identified, do you know what voltages i should be reading there to test it?
                          I read thru that post. At first we seemed to have a similar problem, but then his would turn on full bright after disconnecting the main. Mine will not. Any other ideas other that what bud has suggested i try?
                            I did not have a chance to look at the pinout of MAP3511 compared to pinout of the IC you have on your board yet to verify if we can use the pinout of MAP3511 to troubleshoot your board or not.
                              No worries. Thank u for helping. I will keep looking to see what i can figure out. Im not giving up on this tv yet.
                                BTW, do you have LED tester for testing the whole LED string?
                                  No tester but I went led by led and tested each one with my multimeter. Also, this is a new string, albeit an ebay purchase from china. They all light up brightly when i provide that path to ground. Also, i performed a continuity test to be sure there wasnt a short to ground issue either on the harness or on the strips. Does that suffice for testing them?
                                    It is always to test the LED as the whole string by putting the tester at the LED connector since failure can be in the path where each LED strip is connected to each other and all the way to the LED connector, I always per form that test before putting the LCD panel back together after installing the new LED strips.
                                      Can i run 27vdc voltage through each string and test (9v batteries in series) or does it need to be the full vdc at the connector?
                                        https://www.shopjimmy.com/samsung-bn...re-led-strips/
                                        According to the LED drive Voltage chart, the Voltage is 326V.
                                        So how many pair of wires are connected to the LED connector?
                                          There are 4
                                          2 blue and 2 blk
