I picked up this TV with a problem showing white image.
When I unplug the right ribbon from the T-con to the panel board the right side is white with a dark shade at the edge and the left side shows perfect image.
When I unplug the left ribbon from the T-con to the panel board the left side is dark and the right side shows image but white. After a while the left side turns grey with vertical and horizontal lines. I found online that by swapping the AS15G it fixes images problems but not in my case.
