I tried to replace the atmega162 (despite not having the firmware yet) and now the program detects the chip via usbasp, I also tried to connect the card to the PC to see if there was any sign of life but nothing. Do you think there are other problems or is it only the lack of firmware that does not detect it from the computer?
a curiosity, if I tried to put the firmware of the numark NS6-2 (because that is downloadable), just to try, could I go back to its original once I have found it? Maybe I said bullshit but I would like to understand what happens
please take a look at the firmware of the ns6II, after downloading and extracting it, it gives me strange files, according to you which one should i use? they have no information and no extension I'm going crazy
well that's a windows exe, i cant and wont run that - if you managed to extract files from inside it then let me know.
i know it has an installer in it that tries to put a load of crap in the o.s. related to visual C.
What should I watch? I did not understand correctly, maybe I expressed myself wrong, I do not have the firmware of the ns6 and I wanted to try to load that of the ns6II but as you could see it is in a strange format, so I am facing a dead end
i dont think that file has atmel code in it, just the firmware for the bigger main chip.
try to contact Numark again - the fact that they didnt say no means they may have just not got your message to the right department.
link them to this forum - publicity helps.
the firmware must undoubtedly be loaded into the atmel chip, I don't know which other chip you are referring to, because the isp connector clearly says ISP ATMEL, so the firmware must be loaded into atmel, which chip are you referring to?
The firmware goes inside the Atmel.
The service schematic shows the USB port, but also J13 programming header is connected for this purpose.
The thing is via USB is not possible without there already being a firmware on the device: i.e. you can update via USB, but not load the initial firmware that way.
I extracted the firmware from the installer, but this does not look to be in Intel HEX format. (And also how do you know if the NS6-II model is even similar?)
So it might be something proprietary, I don't really know.
As stj said your best bet here might be to get some info from the manufacturer.
Most likely the firmware is obfuscated, but maybe in that case they could sell you a preflashed new Atmel chip...
what did you send me which controller it belongs to? yes I know that of the ns6II probably will not work I would just try to load it to see if at least it is detected by the pc
That is what they call the "XMOS firmware" in the above screenshot.
-Whatever that is, don't ask me, I didn't design it
That said it is of a size (24KB) which would be in the ballpark depending on used encoding format for the Atmega...
