Samsung ue49mu6120
    Samsung ue49mu6120
    Hi i have Samsung ue49mu6120
    the tv will not turn on, no standby light, power supply BN44-00807F
    Main board BN41-02568B
    BN94-12644a
    i have repaired tv's in the past, i know the basics.....
    when i remove the psu cable to main board i get back lights......
    if any one has repaired this tv or had similar problem..
    Re: Samsung ue49mu6120
    This chassis is famous for its standby firmware rally in SPI Flash W25Q40CL (IC1604).
    If you have a programmer, then copy the contents of W25Q40CL (IC1604) and post it here, I'll fix the dump for you.
      hi how do i copy contents of w25q40l ic1604... eprom chip?
        Using the programmer, you unsolder the spi flash, insert it into the programmer and read the data, save it in BIN format and put it here.
          I don't have programmer, where would I get one from,
            eBay: search CH431A
            Lotas: can i know why the dump must be "fixed" instead of rewritten? thanks
              Well, I don't know whether to buy the simplest "CH341A" or take it from friends who are engaged in electronics repair, without a programmer you will not repair your Samsung, only replace the mainboard.
                Originally posted by Davi.p View Post
                eBay: search CH431A
                I will fix its damaged dump and post the finished fixed here and it will remain to write it back to flash and solder it back.
                  No i've asked why not to provide him a standard dump, and you want his dump, what goes wrong with them?
                    They are not all standard, they may have different software versions.
                      Hi have a programmer CH341A now, please can you post software and drivers.... to use programmer
                      i have removed the main board i can only see ic1603 Winbond 25Q80DVSIG 1737... is this the right chip to copy?
                      rgs Martin
                        Hi, the chip spi flash is under the IC1604 (25Q40CL) heatsink.
                        Driver and program for CH341A "AsProgrammer" posted here
                        https://www.badcaps.net/forum/showth...t=99752&page=2
                          I just bought the same programmer and tried but had no luck. Please let me know if you get it to work. Maybe I’m doing something wrong.
                            chip
                              chip
                              chip read.OK
                                I think so, what do I do now? saved old chip
                                Fixed now.. to download on the chip...
                                Rgs Martin
                                  Yes, write this corrected dump to the same chip, use this instruction when writing.
                                  https://www.badcaps.net/forum/showpo...3&postcount=29
                                    Hi i have got to the stage Seger edition check mark s7 s3 s14 s9 not on the register
                                      Hello, why do you have an empty dump (FF FF FF ...), you should have this.
                                        Hi I'm still getting the same on the status register no s7 etc
                                        The program you added fixed chip 7zip or winrar
                                        Rgs Martin
