Help identify chip A7UH 827 Please
    Please help identify this part. It's from a Zhiyun Smooth 4 sma04 Gimbal Stabilizer. Images attached. Chip label: A7UH 827
    SOT-26 PACKAGE
    Re: Help identify chip A7UH 827 Please
    Silergy makes a chip similar to this in a DFN1.45x1-6
    This is NOT YOUR IC but might be similar and help you in your search: SY8078BDTC
      Kinda makes sense, Vin microsusb 5v output charging a tiny battery LX pin, 1.2v ish
      Maybe I'll try same chip but different package
      Even a different manufacturer should be fine as long as same pin layout
        MP1652GTF-Z
        https://aliexpress.com/item/1005003171086368.html
          OMG. How did you know?
            He used the correct number ATU not A7U, I could not make out the pin style because they were covered by your tweezers
            Another ic with the same marking (ATU) is MP1476GTF
            The MP1652GTF-Z seems to be more available
              Hmm but it really was A7u as per picture. Interesting
                It is an odd looking "7" compared to the date code "7"
                  Now it makes sense. 7 on bottom is much better then 7 on top. I'll keep it in mind to search for letters as well.
                    This could be due to heating, breakdown inside the crystal, because of this, the "T" in the center was deformed.
