Motherboard PU551LA Ver 2 with Intel i5 4210U
I bought the motherboard as faulty to replace a similar one not repairable because it was completely shorted.
3V EC was shorted to ground because of EC chip. IT8585E FXA replaced with IT8585E FXS. Motherboard now works and I am able to recharge the battery, install Windows and update BIOS from Ver 207 to 210 with EZ Flash, but it has the following problem: Every time I power off the laptop with power switch or with Windows shutdown the laptop apparently turns off, but the power LED remains on and it's not possible to restart the laptop. Resetting the pc by keeping the power button pressed for 6 seconds turns off the Power led and boot works fine.
Same behavior with power off from bios or Windows.
I tried disabling fast boot, loading BIOS default, playing with bios parameters etc. : still same problem. I noticed that along with 3.3V and 5V, the 1.05V is always on (which surprises me). Also if you suspend from Windows or close the lid, restart is not possible as with shutdown.
Any suggestion?
Thanks in advance
Any suggestion?
Thanks in advance
