TV has 2 strings of LED backlight. 1 string had 1x LED failure. Replaced all LED light bar (thought about replacing just 1 bar but new bar LED color more white compared to old)
The large screen and HiSense reflector paper assembly presented some challenges over the smaller screens.
- 75" TV is huge, need 2x large work surface (1 for TV, 1 for LCD panel)
- White reflector paper in the tub is secured by 10 columns and 1 row (on top the tub) of double sided sticky tape. Took awhile (need to go slow to avoid/minimize damage) to remove with minimal damage.
- LED bars are glued down so need to have double sided tape to mount new LED bars. I just use small pieces of Tesa tape near the black glue points.
- Putting the reflector paper back properly has some challenges. double sided sticky tape is less sticky on 2nd use. Tub need to be evenly supported on a flat surface (I removed all boards and cables and lay it on a mattress) so the paper goes in flat and even. If not, will have LED bright spots presumably from uneven reflector paper install.
