toshiba c850d black screen
    hi
    Toshiba C850D PLABX CSABX UMA DSC rev 2.1
    builtin amd cpu
    chipset amd
    turning on with black screen and 0.9 amps consumption
    all the voltages needed are present
    i try flash bios with different files but same result
    i suspect in cpu or chipset .
    Re: toshiba c850d black screen
    Consumption on dc supply(after turning on)
    01.With Ram stick
    02.Without ram stick?
      01.With Ram stick
      almost a same consumption .
        That does mean ram is not read . Do check ram requirements,flash known good clean me bios as first steps.
          but i have ram voltage 1.5v and vtt 0.75
          can you clean to me the origin dump .
          i can't fine any schematic for this model just a boardview .
          Last edited by SMDFlea; 05-27-2023, 04:06 PM. Reason: Bios removed,this isn`t the bios requests section...
            I think this one is amd apu-so no me region here.Its not enough to have 1.5V/0.75V for ram to work. One needs to check whether communication is there on SDA/SCL pins and Ram is being reset or not. You need a scope to check the communication.
              yes the cpu is amd apu
              i check and found all ram requirements
              VDD SPD = 3.3V
              SDA/SCL =3.3v
              DRAM_RST# = 1.5V
              also i try a different ram and same result .
                Link the boardview here. have you checked ram slots full requirement? there should be a 3leg or 6 leg mosfet between FCH and ram slot for SDA/SCL communication. So there should be 2 such mosfets and take a close look on them.
                  according to the boardview SDA/SCL connection between fch and ram slot is direct no mosfets .
                  i think i check all requirements
                  VRef_DQ
                  VTT
                  VRef_CA
                  VDD SPD
                  SDA data
                  SCL clock
                  DRAM_RST#
                  all are ok nothing missing .
                    https://www.badcaps.net/forum/showthread.php?t=117483
                    If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
                      Yes,asper bdv nothing is inbetween ram slot /FCH wrt SMBUS comminication. Seems like FCH issue but cant say with 100% certainity without measurement pics on SDA/SCL/Dramrst# on scope.
                        yes i think so
                        from ram slot under the scope
                        sda on pin 200 =3.3v
                        scl on pin 202 = 3.3
                        dramrt on pin 30 = 1.5
                        i think i get the right reading .
                          Originally posted by mo000 View Post
                          yes i think so
                          These voltages are correct but that doesnt proves there is communication. That can be only confirmed by oscilloscope where you can observe the pulses.
                            These voltages are correct but that doesn't proves there is communication. That can be only confirmed by oscilloscope where you can observe the pulses.
                            yes i know but unfortunately i don't have oscilloscope .
                              If you power up without the ram, does the logic board send out the missing ram beep pattern?
                                no
