Help with a Lenovo V15-ADA 82C7
    Hi there,
    My Lenovo V15-ADA 82C7 has stoped working with the following simptoms. It have a blank screen and no pictures displayed on HDMI too (F2 fuse it's OK). It's powerd up connected to charger (or on battery) it charge the battery and the fan it's spinning but blank screen. If the DIMM (1) 8GB is removed there are no beep error. Vesko356 has kind to provide me a schematics and it seems the voltages are ok (at last where i got measured it with a multimeter). The only abnomaly is the PQ5908 which it seems to be hotter than othee mos-fets around.
    What i can try next? Is the BIOS got corrupted somehow?
    Re: Help with a Lenovo V15-ADA 82C7
    Do you have dc power supply? If yes, is there variation in current consumption when turned on? DramRST# pulled low??
      Unfortunately the one i have it not display the power consumption (only voltage). I need to find anpther one to test this. Anyway thank you for sugestion.
        You could've measured DRAMRST# and posted it here.
          Hi and thank you for reply. Acordig to schematic publisher here (pg. 14) the point of measure DRAMRTST# is on CD120? If not please let me know where to measure it. Thank you!
            I have noticed the chips from original memory (PC2666) are get hot, when inserted. With another DDR4 (PC3200) it not start as well but the chips on the DIMM it remain colder.
              Yes, measure it there on Cd120
                When the laptop is powered off (cherging the battery) the consumption initialy is 0.12A and after 2 second it increase to 0.95A. When powered on it decrease from 0.95A to 0.85A.
                  For the moment i have trouble to find C120 because it is not marked on board. Will look closer and let you know.
