Laptop battery charging circuit
This is a sticky topic.
    Re: Laptop battery charging circuit
    what about the battery that was long without charging and it's dead now? i open the battery, charge it from external PS, and how to get it to work again,since the managment chip is probably not turning the output...
    i did that multiple times,and it never works...just yesterday, i charged it from external PS,and it's now charged, i plug it in and it doesn't recognize it, it starts to charge for few seconds and that's that...
      Thanks..Very useful especially for beginners like me.
        Controller inside the battery is becoming locked if the cells were deeply discharged, so even if you charge the cells you need to reset the controller. It can be done with different ways, there are hardware and software tools like NLBA, be2works, etc....
          Thank You for a great research!
          One question to: AC adapter not detected, wrong AC adapter
          what is AD_ID voltages for HP, Lenovo and other resistive dividers. (Dell has one-wire bus for it). If that ID voltages are model dependant, some examples please.
          Konstantin.
            Thank you for this useful share.
            I have a question, which pin of kbc will activate the charging ic to charge the battery?
              Thank you for the Information and starting guide for Charger IC !
                thank you, good information
                  excellent contribution, thanks for sharing
                    Very useful information. THANKS .
                      Nice guide, Thank you!
                        what about charger center pins and charger detection circuits?
                          thank you So much.
                            Wonderful post. I had a low battery warning recently on a hp 14-018la laptop. Turns out it was the battery that needed to be replaced. Thanks
                              Thank you for the information 😊
                                you guys are really amazing !
                                  Great thread! Thank you for sharing.
                                    Very educating content thanks a lot it helped
                                      Thank u
                                        Some great information here! I'm currently working on a laptop motherboard that wont power on (no power LED even lighting up) so this information is going to help me a lot in the fault-finding process
                                          Thanks for this wealth of information all in one
