Hi! I have a Thinkpad LA-C421P with no power to the system. No boardview nor schematic available. When connected it draws only 9mA.
After checking for shorts on coils I found no shorts and only then I injected 20V to the Main 20V system line (After the sensor resistor). The Laptop boots up Ok so the problem is charger is not driving the first 2 N-Channel Mosfets.
Following Piernov's Guide https://www.badcaps.net/forum/showthread.php?t=90356 I found out BQ24780 has:
VCC -> 19.8V
REGN -> 6V
ACDET -> 2.65V
ACOK -> 3.3V
but CMSRC is -> 0V and ACDRV -> 0V too.
I checked both input N-Channel Mosfets. Both seems fine, but I replaced them anyways.
Still no CMRSC or ACDRV.
I changed BQ, same behavior.
I don't know what to check next.
VCC -> 19.8V
REGN -> 6V
ACDET -> 2.65V
ACOK -> 3.3V
