Panasonic touchbook cf-53 mk2/mk4
    Re: dump Bios eeprom25Q128A- Panasonic touchbook cf-53 mk2
    Originally posted by afroindustries View Post
    can someone post or pm the requested bios file? thank you. best regards
    Post your bios backup .
      try this
        Re: Panasonic touchbook cf-53 mk2/mk4
        Hi, I'm trying to unlock my bios. The Machine is a CF-53 Mk4 CF-532SLZACM and I have attached my bios dump. Any help is greatly appreciated.
          try.. and goodluck
            rioreno, Thanks sir, I tried to load that and I'm still locked out. I compared the original files to see what you changed, you were alot more cautious than what I saw in the other BIOS mods. Are you pretty familiar with the layouts of these BIOS' ?
              i really sorry....
              this my bad...
              i was forget to clean 2nd nvram...
              now this is should works..
              try, and goodluck
                thanks sir
                  Do you know if this will work on another laptop of the same exact model ?
                  So I threw caution to the wind, and it seems to
                  Does make the serial number the same though and loses things like the total power on time
                    Well, it works but might have issues. Like slow boot, wrong serial numbers and other data or some other errors. So it is always better to upload dumps from all machines and patch them separately.
                    If you still have the backup, just upload it.
                      agree with @RethoricalCheese..
                      if you have another device with passwprdbios or faulty bios, BETTER upload your backup here..
                      someone will help you , but you must be patience...
                      FYI : i have another case with same type CF53-4, with password not only at store at NVRAMs.. check this..
                      https://www.badcaps.net/forum/showpo...80&postcount=4
                        Rioreno, I foolishly jumped the gun, The machine does boot and the bios seems open, but there is a slight pause when it powers up. I think it may be doomed to just be that way.
                          You mean from pressing power button to displaying a logo takes time? Cleaning ME region should fix that.
                            Originally posted by rioreno View Post
                            try.. and goodluck
                            Hi!
                            Help me please with CF-53 MK3 bios lock.
                              Originally posted by lex00 View Post
                              Hi!
                              try this.. CF53-MK3
                              goodluck and please confirm
                                try this.. CF53-MK3
                                Thank you! It's work!
                                  That is correct, it also has the serial of another machine displayed on it as well in the bios. But I'm currently away from home without access to the machine or tools to remove the chip again. I will post the bios when I have access if you'd be willing to clear that section out . Thanks
                                    DMI block with serial at A80000 adress in bios.
                                      What do you folks use for hex editing the bios ?
                                        http://www.x-ways.net/winhex/index-m.html
                                          Hex Editor Neo on windows, hexedit on linux.
