Hp probook 640 g1 bios
    Re: Hp probook 640 g1 bios
    but its not working
    no display
      Originally posted by javed964 View Post
      but its not working
      no display
      write the bios chip again with the original bios and see if it works..
        sorry my mistake programmer problem.
        100% Working Thank you so much.
          Please unlock this bios
            BIOS guides, methods, resources and tools
            3. Password removal by laptop brand
            3.6. HP
            BIOS password is stored in NVRAM in the BIOS. BIOS editing and re-flashing is required.
            You can use the automatic unlocker at: https://www.badcaps.net/forum/showthread.php?t=98539
            Another tool that may also work: https://www.badcaps.net/forum/showthread.php?t=103184
            Become a Badcaps supporter
            Thanks to all supporters.​
                HELP BIOS HP 640 G1 corrupt
                Good evening,
                my problem is the following: the screen stays black, the pc launches, I have flashes on the caps key (5) and the fan is running at full speed. I'm thinking a corrupted bios. Here is the extracted bios.
                Thank you in advance for your help.
                  Re: HELP BIOS HP 640 G1 corrupt
                  Originally posted by FP1975 View Post
                  Good evening,
                  try this
                  all donations are welcome,
                    Originally posted by volinakis View Post
                    try this
                    Hello, thank you for the file but:
                    - the pc starts, black screen
                    - 3 beeps (5 before)
                    -fans running at full speed
                    The problem is still here...
                    Thanks in advance for the help
                      try
                        try
                        For this second file, nothing happens. The pc does not start. Here is some info from the pc:
                        motherboard 6050A2566302-MB-A02
                        I5 4300u
                        SN: CNU41391D7
                        SKU: D9R55AV
                        CT: PEBHU001X6H192
                        Thanks in advance
                          I5 4300u
                          SN: CNU41391D7
                          SKU: D9R55AV
                          CT: PEBHU001X6H192
                          Thanks in advance
                          try this bios and if it works then write DMI with BCU or wndmifit
                          https://www.badcaps.net/forum/showpo...2&postcount=11
                            need to 6050a2566402-mb-a02 bios. thanks
                            my bios.
                              Re: need to 6050a2566402-mb-a02 bios. thanks
                              my bios.
                              https://www.badcaps.net/forum/showth...2566402&page=4
                              TRY FROM POST #61
                                I need reset password please, here is the file
                                  Read post #225
                                    need help to repair this Hp 640 G1 bios file
                                      Re: Hp probook 640 g1 uma
                                      Originally posted by peste View Post
                                      try..
                                      Hello, I have problems with my bios, it only turns on the power led and it goes off quickly like a flash, I tried other bioses but it tries to turn on and nothing, I check my board and I thought if someone can repair my bios, I leave the backup here in case they can repair it, thanks
                                        Good evening,
                                        I have exact the same problem. I tried to replace the ME Region.bin and reflash the modified outimage, but it does not change anything.
                                        Model: HP Probook 640 G1
                                        Mainboard: 6050A2566302-MB-A03
                                        Extracted BIOS and board images are attached.
                                        Thanks for help!
                                          Thanks for help!
                                          You must post the serial number.
                                          Read the rules before posting:
