Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 06-28-2020, 04:49 PM   #1
JUAN MANUEL
City & State: JAEN
My Country: ESPAÑA
Line Voltage: 230 VAC 60HZ
I'm a: Knowledge Seeker
Default Hantek 6022BE IN SHORT CIRCUIT
Hello and thanks to everyone
I have a Hantek 6022BE brand oscilloscope which due to my error causes a short in a board at a network voltage of 220V, and as expected the oscilloscope does not work
He replaced a protection zener diode and a fuse resistor at the input that were short but the oscilloscope still does not work for me so I keep investigating
Injection 5V (With regulated source) at the input and gives me a consumption of 300 mAh and two integrated with 74HC4051 license plate (multiplexer and demultiplexer) are heated, each of these integrated corresponds to the input of the oscilloscope probes
I give tension directly to these integrated (vcc and ground) and they heat up and I continue with the same consumption, but when I test them with the multimeter they do not give me short between these two terminals (vcc and ground)
Before I lift them and continue checking I would like if you have any experience or problem related to these types of integrates and if they are prone to short
Attached datashep of the integrated and their situation on the board
File Type: jpg Hantek-6022BE-Oscilloscoop-binnenkant.jpg (813.6 KB, 8 views)
JUAN MANUEL is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
