Altec Lancing ACS41
Altec Lancing ACS41
These are pictures and spec sheets of the IC'sLast edited by budm; 06-26-2020, 10:21 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None
Re: Altec Lancing ACS41
I know the LM324 has a gritty sound/mid-range blare to it due to the cross-over distortion so I change them out. Quad op-amp alternates:
LM837 is older and drop in. OPA4134 is very good as well.
The LM833 and OPA2134 are the high performance duals, to ditch the NJM4560 but it is not as bad.
TA8248, TA8229. Notes: (***V) Voltage with headphone plugged in. When headphone is plugged in the VCC2 from the switched headphone jack is cutoff so there will no VCC2 on pin 8 of the TA chip.
Pin 1: N.C.
Pin 2: Bootstrap 2 =18.20V (0.56V)
Pin 3: Output 2 = 9.42V (0.51V)
Pin 4: VCC1 = 18.47V (18.47V)
Pin 5: Output 1 = 9.03V (1.00V)
Pin 6: Bootstrap 1 = 18.16V (0.52V)
Pin 7: PWR-GND
Pin 8: VCC2 = 18.47 (0.05V)
Pin 9: Ripple filter = 9.63V (0.51V)
Pin 10: NF1 (Negative Feedback 1) = 0.60V (0.95V)
Pin 11: Input 1 = 0.06V (0V)
Pin 12: Input 2 = 0.02V (0V)
Pin 13: NF2 (Negative Feedback 2) = 0.60V (0.56V)
Pin 14: Pre-Gnd 1
Pin 15: Pre-Gnd 2Last edited by budm; 07-03-2020, 08:11 PM.Never stop learning
