Just wanted to share a strange issue I was having when trying to get this system running again. It was working perfectly fine when put away.
A7V8X r2.01 XP2500(@2200mhz)+ 2gb DDR 400, AIW 9600xt 128mg, Audigy, Pioneer DVD-105 , DVR-115, Maxtor 300gb, seagate 160gb, Enermax Tomahawk 405w
A few years later when trying to get the system up and running again I could not get it to boot with two hdd's connected no matter how I set them up. Master or slave IDE 1 or 2, I couldn't even get the seagate drive to detect by itself after awhile, however with just the Maxtor and dvd drives it would boot to either XP or 98 without issues.
Because with just the two hdd's connected both would fail to spin up properly I initially thought the psu was at fault, however the same issue was there with a known good psu, and the psu caps tested fine.
All the caps on mb appeared ok on visual inspection however after removing to test I found the 3300uf 6.3v KZG all read around 5300uf and the 1500uf 6.3v KZE were reading around 2000uf.
Decided to replace them all with some Nichicon HD and HW I had on hand and all is well.I just thought the symptoms were strange and maybe it would help someone out to know what my solution was.
