Macbook Pro 15" 820-2850-A no PPBUS_G3H
    Hello have same issues with 820-2850 MacBook.
    not getting PPBUS_G3H after U7000 getting 18 volts in pin5 from Q7030 but not in pins 1,2 &3 pin-4 gate was also zero volts checking U7000 pin 24 CHRG UGATE has zero, verify pin-19 VDD has 5.1 volts, pin-3 CHRG ACIN has 7.61 volts, pin-2 CHRG DCIN 16.89 volts, has a green lights in mag safe which I have a 3.4 volts in pin 14 SMC BC ACOK.
    what condition that U 7000 suppose to have in order to put high voltage in Q7030 Gate? what else do you think I can check further.
    Thank you guys in advance for your big help
    Re: Macbook Pro 15" 820-2850-A no PPBUS_G3H
    Did you replaced U7000 already?
      Thank you for replying
      Yes I did
        Did more testing found that Q7080 in reverse current protection side not getting the PPDCIN_G3H in pins 1 &2 ( no gate voltage in pin-3) but have 18 volts in pins 4&5 because pin 6 (gate has 17.2 volts)
          Q7080 is control by U7000. Please check voltage divider R7081, R7080 the gate should be lower than the input voltage in order to open the MOSFET.
            My U7000 VDD pin19 not getting the PP5V_CHGR_VDD which supposedly 5.1 volts but nothing where this PP5V_CHGR_VDD coming from?
            Thank you guys
              pin 3 should get something like 4 volt check resistence R7010 r7011
              check R7021 r7022 value
                Please clarify.
                  Did check these resistor they came out good ( resistance value) but where is the PP5V1_CHGR_VDD to power U7000 coming from. I am not getting voltage values on the pins because U7000 is not power on pin-19 VDD 5.1 volts is missing
                    PP5V1_CHGR_VDD is created by the ISL6259 itself when it receives power on CHGR_DCIN.
                      Thank you so much let me check those voltage divider again, R7010 30.1K and R7011 9.31K also R7021 and R7022 both 10ohms
                        normal u700 voltage:
                        U7000 / ISL6259HRTZ
                        Pin01 = 0v (probe 200) CHGR_AGATE
                        Pin02 = 18.54v (measured on C7005) PPCHGR_DCIN
                        Pin03 = 4.46v (probe 176) CHGR_ACIN
                        Pin05 = 1.13v (probe 175) CHGR_ICOMP
                        Pin06 = 3.49v (measured on R7012) CHGR_CELL
                        Pin07 = 0.80v (probe 153) CHGR_VCOMP
                        Pin08 = 2.05v (measured on R7016) CHGR_VNEG
                        Pin09 = 0.04v (probe 154) CHGR_AMON
                        Pin10 = 3.48v (probe 962) SMBUS_SMC_5_G3_SDA
                        Pin11 = 3.49v (probe 1044) SMBUS_SMC_5_G3_SCL
                        Pin12 = 3.49v (probe 155) PP3V42_G3H
                        Pin13 = 3.18v (measured on R7000) CHGR_RST_L
                        Pin14 = 2.38v (probe 1018) SMC_BC_ACOK
                        Pin15 = 0.07v (probe 157) CHGR_BMON
                        Pin16 = 11.45v (probe 156) CHGR_BGATE
                        Pin17 = 12.27v (C7050) CHGR_CSO_N
                        Pin18 = 12.28v (C7050) CHGR_CSO_P
                        Pin19 = 5.08v (measured on R7001) PP5V1_CHGR_VDD
                        Pin20 = 5.07V (probe 202) PP5V1_CHGR_VDDP
                        Pin21 = 0.18v (probe 1036) CHGR_LGATE
                        Pin22 = GND
                        Pin23 = 11.84v (probe 1045) CHGR_PHASE
                        Pin24 = 11.92 (probe 1034) CHGR_UGATE
                        Pin25 = 16.01v (probe 214) CHGR_BOOT
                        Pin26 = 16.30v (probe 1050) CHGR_SGATE
                        Pin27 = 18.43 (C2070 ) CHGR_CSI_N
                        Pin28 CHGR_CSI_P = 18.43 (probe 201) CHGR_CSI_P
                        post your voltages on u7000.
                        you have still original u7000 or u already tried to replace it ?
                          Thank you so much, here are y readings in U7000 ( just replaced it ), sorry not sure why when I posted the numbers move close to left side
                          U7000 / ISL6259HRTZ My reading
                          Pin01 = 0v (probe 200) CHGR_AGATE 0
                          Pin02 = 18.54v (measured on C7005) PPCHGR_DCIN 17.51
                          Pin03 = 4.46v (probe 176) CHGR_ACIN 4.24
                          Pin05 = 1.13v (probe 175) CHGR_ICOMP 0
                          Pin06 = 3.49v (measured on R7012) CHGR_CELL 1.706
                          Pin07 = 0.80v (probe 153) CHGR_VCOMP 0
                          Pin08 = 2.05v (measured on R7016) CHGR_VNEG 0
                          Pin09 = 0.04v (probe 154) CHGR_AMON 0.033
                          Pin10 = 3.48v (probe 962) SMBUS_SMC_5_G3_SDA 3.4
                          Pin11 = 3.49v (probe 1044) SMBUS_SMC_5_G3_SCL 3.4
                          Pin12 = 3.49v (probe 155) PP3V42_G3H 3.41
                          Pin13 = 3.18v (measured on R7000) CHGR_RST_L 3.41
                          Pin14 = 2.38v (probe 1018) SMC_BC_ACOK 3.27
                          Pin15 = 0.07v (probe 157) CHGR_BMON 0.045
                          Pin16 = 11.45v (probe 156) CHGR_BGATE 0.002
                          Pin17 = 12.27v (C7050) CHGR_CSO_N 0.024
                          Pin18 = 12.28v (C7050) CHGR_CSO_P* 0.023
                          Pin19 = 5.08v (measured on R7001) PP5V1_CHGR_VDD 5.071
                          Pin20 = 5.07V (probe 202) PP5V1_CHGR_VDDP 5.071
                          Pin21 = 0.18v (probe 1036) CHGR_LGATE 0
                          Pin22 = GND GND
                          Pin23 = 11.84v (probe 1045) CHGR_PHASE 0.055
                          Pin24 = 11.92 (probe 1034) CHGR_UGATE 0.052
                          Pin25 = 16.01v (probe 214) CHGR_BOOT 4.769
                          Pin26 = 16.30v (probe 1050) CHGR_SGATE* 17.27
                          Pin27 = 18.43 (C2070 ) CHGR_CSI_N 17.52
                          Pin28 CHGR_CSI_P = 18.43 (probe 201) CHGR_CSI_P 17.5
                            how many omh on f7000 (without psu) ?
                            u7000 replaced was new ?
                            can u try with another dc-in and psu ?
                            can u pass again lateral solder of u7000 with thin tip and flux+leaded solder ?
                              My board is 820-2850 so I don't have F7000 what I have is F7040 if that's what you mean, anyway it was 000.6 ohms, yes already replace U7000 and also did lot of flux to re-heat and performed lateral solder but don't have leaded solder so I used unleaded one. Use 85 watts Apple PS also bench PS set @ 18.5 volts with 4.6amps. And now is stop my bench PS about few seconds after apply voltage. Something shorting out but cannot find it I also use thermal gun but did not see something heating up. I am really confused now.
                              Thank you so much for your patience in giving me advice.
                                yes i mean f7040. remove f7040, see if 12.5 volt comes in one side of f7040. check resistance in omh ( without power) on each poin of removed f7040. 1 side is PPBUS_G3H and other side is ppvbat_g3g_chrg_reg.
                                if low reading (Short) on one of this side do that:
                                if short is on PPBUS_G3H check u7201 if all looks ok. is so inject 1 volt and see if u7201 or something else get hot
                                if short is on ppvbat_g3g_chrg_reg check u7000 and inject 1 volt and see if something get hot near u7000
                                if nothing get hot, increase voltage step by step to max 2-3 volt.
