Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 10-27-2020, 02:36 AM   #41
beetle1303
City & State: Singapore
My Country: Singapore
Line Voltage: 230VAC 60Hz
I'm a: Knowledge Seeker
Default Re: Tefal GV8962 Pro Express steam iron - no power
Quote:
Originally Posted by budm View Post
So now you are saying the resistance on C2 no longer show 30 Ohms?
Do you have 24Vdc on C2?
You also need to find out if you also have low Voltages to runs those IC or not
Yes, D3 no longer show 30ohm. It shows 532ohm in resistance mode, and 579 in diode mode.
C2 shows 0.1v and U1 shows 0.2v between Drain pin and each of all other pins.
Pressing the BP5 Power on/off button has no effect..
beetle1303 is offline   Reply With Quote
Old 10-27-2020, 11:43 AM   #42
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
does u1 get power from the resistor?
CapLeaker is offline   Reply With Quote
Old 10-27-2020, 12:34 PM   #43
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
You are not getting Voltage feeding the D pin of the IC, you need to check the Voltage between the two legs of main filter cap C4 (Green cap next to the resistor) first and also check your soldering works.
BTW, 100 Ohms is too high for that fusible resistor, but of testing purpose t is OK for now.
__________________
budm is offline   Reply With Quote
Old 10-27-2020, 07:52 PM   #44
beetle1303
Arh... indeed, one end of R1 solder joint is done poorly.. Reworked, and now D pin & C1 (I believe not C4) get 325Vdc, and C2 gets 24Vdc.
But pressing the power on/off button still no led light..
*Noted on R1 being a 100 ohm resistor, should get a 2W 8-10 ohm replacement?
Old 10-27-2020, 09:14 PM   #45
budm
budm's Avatar
My Country: USA
At this point you can leave the 100 Ohms resistor for testing for now.
So the 24V buck converter is working now, now we need to trace out the other power supply section for low Voltage that is used for running those IC's (U3, U4) next.
So look up the part number of some of those IC's so you can look up the spec sheet to locate the VCC pin of the IC then you can find out if the VCC is present or not for the IC's to run.
Check Voltage of U2, it looks to be LDO Regulator IC.
I also see some bad solder joints, one looks burnt, others you can see ring developing around the joint, so look for ring around the solder joints and resolder them.
BTW, that small white connector, what is connected to that connector?
Old 10-28-2020, 01:19 AM   #46
beetle1303
The black color that looks burnt is permanent black marker ink, on the the joints that have wired soldered directly onto. The ring around the solder joints - except for the huge wire joints with black marks, practically all the joints has some sort of indentation. Some looks like a ring, most are just dings. I re-soldered most of them.
I looked up for and these are the 2 ICs:
1) Top, bigger one: PIC16F1933: pin 19 & 20 measure 0.03Vdc
2) Bottom, smaller one: HC595A: pin 8 & 16 measure 0.03Vdc
Pressing power button on/off has no effect on the readings.
Old 10-28-2020, 01:35 AM   #47
budm
budm's Avatar
My Country: USA
You need to check Voltages of U2 which looks like LDO Regulator IC.
Old 10-28-2020, 01:50 AM   #48
beetle1303
How do I check this U2?
I put DMM in Volt mode, put black on common pad, and Red on each lead:
Left one reads 23Vdc
Middle and Right ones read 0Vdc
*left side is bulged..
Old 10-28-2020, 04:22 AM   #49
beetle1303
I just googled to learn more about LDO. If the picture is a correct pinout of a LDO, then it measured input is 23Vdc, and output is -0Vdc.
Does this mean this LDO is faulty/open?
Old 10-28-2020, 01:34 PM   #50
budm
budm's Avatar
My Country: USA
https://www.badcaps.net/forum/attach...9&d=1603871079
It looks like it is blown up when the high Voltage dump occurred.
Circuit ground for your probe will be the Negative leg of C2, then test Voltage on each leg of that U2.
It looks like the center pin is ground, if that is the case then will not be the same as typical 1117 regulator. You can verify if center pin is connected to circuit ground or not by checking the resistance between C2 negative leg and center pin of U2 to see if it shows <1 Ohm or not. You should also check the resistance of the two outer pins against ground.
If you cannot read the print then it will be hard to figure out what the output Voltage should be, it may rated as the same Voltage for the IC's VCC.
Old 10-28-2020, 03:34 PM   #51
budm
budm's Avatar
My Country: USA
BTW, look real close at C6 and C7 soldering joints connected to U2 pin 1 and pin 3, they do not look right.
Old 10-28-2020, 07:23 PM   #52
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
The LDO looks blown up to me. Check C6 & 7 for short and check the capacitance.
Old 10-28-2020, 10:13 PM   #53
beetle1303
Black probe on C2 -Ve, Red probe on
Pin1: 23 Vdc / 146 ohm
Pin2: < 1 Vdc / < 1 ohm
Pin3: < 1 Vdc / 14 ohm
Black probe on Pin2: Red probe on
Pin1: 23 Vdc / 152 ohm
Marking on U2 is completely not readable.
*** Just to be clear: Pin1 is on the left and Pin3 is on the right of the picture I attached.
Old 10-28-2020, 10:17 PM   #54
beetle1303
Quote:
C6: 178 ohm / 0L on capacitance
C7: 14 ohm / 0L on capacitance
U2 does looks and feels bloated on the Pin1 side.
Old 10-28-2020, 10:31 PM   #55
beetle1303
Pin1 to C6: < 1 ohm
Pin1 to C7: 210 ohm
Pin2 to C6: 180 ohm
Pin2 to C7: 15 ohm
Pin3 to C6: 210 ohm
Pin3 to C7: < 1 ohm
Old 10-29-2020, 12:36 AM   #56
budm
budm's Avatar
My Country: USA
As shown in your picture: Pin 1 (Right pin) of U2 is connected to C7, Pin 3 (Left pin) is connected to C6.
I do not understand why your readings show Voltages. Are you checking the resistance of C6 and C7 with POWER applied to the unit while doing resistance test?
Old 10-29-2020, 01:33 AM   #57
beetle1303
Sorry for not stating it clearer, I powered on to read voltages, and powered off to ready resistance, and recorded them in the same row..
So my reference of Pin1 & Pin3 is reversed. Based on your picture:
Pin3: 23 Vdc / 146 ohm
Pin1: < 1 Vdc / 14 ohm
Pin3: 23 Vdc / 152 ohm
Old 10-29-2020, 01:47 AM   #58
beetle1303
I removed U2 (I don't have a proper tools and skillsets, and damaged Pin3 pad).
With U2:
Without U2:
C6: 539 ohm / 103 uF on capacitance
C7: 20.8 ohm / 0L on capacitance
** Pin1 resistance now 20.8 ohm vs 14 ohm previously.
Old 10-29-2020, 02:12 PM   #59
budm
budm's Avatar
My Country: USA
With U2:
Without U2:
Now check the resistance between GND and VCC pins of the IC's.
Old 10-29-2020, 07:48 PM   #60
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
I think C7 may be shorted too. Take it out and remeasure it out of circuit.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
