Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
The replacement as follows:
1. IC7905 : TNY264PN (first found exploded)
2. Q7915 : BT169D (exploded too)
3. IC7901 : 1608B (controller ic)
4. IC7601 : DDA014 (resonance controller)
5. R7918 : 2,2 ohm and has output for 2v
6. R7914 : 2,2 ohm
The power supply board is DPS-143BP-3A, RUNTKA 796WJQS (i attached in this thread)
The Power Factor Corrections block for main 3 bulk capacitors (C7800A, C7800B and C7800C and mosfet Q7801 has 223v output.
Resonance Converter block for Q7602 has no voltage out (0 v) however for Q7601 still has 223v.
Meanwhile for AC Det block at pin number 8 of TNY264N has 223v as well.
But at Q7915 has 5 v, C7915 has 2v, and R7918 also has 2v.
The output pins to the mainboard is as the following:
PD 1-2 = PNL 12v
PD 3-4 = SGND
PD 5-6 = S13,2v
PD 7-8 = UR13,2v
PD 9-10-11-12 = SGND
PD 13 = AC DET
PD 14 = PS ON
PD 15 = BU5v
PD 16 = PNL-POW
PD 17 = PWM1
PD 18-20-21 = NC
PD 19 = Dimmer
PD 22 = ERROR
PD 23 = PWM2
PD 24 = STB
Right now i'm still struggling to find out what the problems is and i got stuck!
That's why i'm trying to share in this forum, hope someone could give me advices and tell me what to do in order the tv could be fixed.
Thank you.
6. R7914 : 2,2 ohm
PD 1-2 = PNL 12v
PD 3-4 = SGND
PD 5-6 = S13,2v
PD 7-8 = UR13,2v
PD 13 = AC DET
PD 14 = PS ON
PD 15 = BU5v
PD 16 = PNL-POW
PD 17 = PWM1
PD 18-20-21 = NC
PD 19 = Dimmer
PD 22 = ERROR
PD 23 = PWM2
PD 24 = STB
Thank you.
