Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
    Please remove the password.
    Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
    post your full backup with spi programmer...
    your post files only bios region, no me region...
      hi
      please bios password clear.
        Originally posted by recep1982 View Post
        hi
        try this...
          Originally posted by rioreno View Post
          try this...
          Hello.
          This bios dump can be used in multiple CF-53's OR it's unique per laptop?
          Thank you!
            Afaik it contains SN etc and probably ME is not cleaned so it is way better to just upload your own dump and get the password removed on that.
              So if we clean the ME and leave the SN as is it will be possible to work fine?
              I ask because i'll receive a pallet with 30 laptops for unlock.
                Warning Mac adress and UUID
                if used in the same corporate network.
                  So i must change the MAC address and UUID in every bios.
                  Perhaps it will be easier if i remove the bios password on every bios my self.
                  Is there any guide for CF-53 ?
                    that is to say, not understood
                      I mean if there is any online guide with instructions on how to remove the bios password from CF-53 dump by my self.
                      It's not right to upload 30 bios dumps and wait others to work for me.
                        here sur bad caps , just compare with other files
                        edit :
                        I forgot the 01 at the end and replace by 00 and not FF
                          edit :
                          So clear everything with 00 including the 01 @ 00AB3090x03 ?
                            yes, beware the address changes for each bios.
                            Search with the keywords "AMITSESetup".(the second often)
                            I gave you the technique for the supervisor password.
                            It can have the user's password too.
                            It is just above if there is a.
                            It will always start with 5B.
                            Look at my picture here you will understand.
                            https://www.badcaps.net/forum/showthread.php?t=88289
                              Ok, i'll let you know when i receive the pallet. Thank you!
                                Please help me to reset CF-53 password.
                                What is the procedure?
                                  edit :
                                  Hello, I have done what you indicate, and it has worked for me. It asked me for a password to enter the BIOS, and now it no longer asks me for it. Thanks a lot!!!
                                    Hi, I have a CF-53 that is also locked,
                                    can someone help me ?
                                      post your locked bios file please
                                        please remove password
                                        thanks
