Samsung Galaxy S5 no sound
    Hi, I'm new here.
    I have a Samsung Galaxy S5 which produces no sound through either the top or bottom loudspeaker. The top loudspeaker produces a constant, very faint high pitched squeal.
    I have tried:
    1. Using the housing of another S5, as this housing contains the top loudspeaker.
    2. Replacing the bottom loudspeaker with a new one.
    3. Full reset.
    The symptoms do not change after the above changes. The phone works fine apart from this.
    The phone operating system is Lineage 9.
    I have a soldering station, multimeter, hot air gun, handtools, etc.
    Thanks for any troubleshooting and repair help.
    Re: Samsung Galaxy S5 no sound
    I've found that actually the ear speaker is working. Turning up the 'in call volume' in setting I can hear it over the squealing sound. No such luck with the ringer volume, or playing music/Youtube videos though, which produce no sound at all through the main speaker.
      Is this the original version from 2014?
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        There's a channel on YouTube that's fixed the audio on more than on S5 by reflowing the audio ic.
          Its the G900F model. The OS is LineageOS.
            Mine is the G900R4. I wonder how different the specs are...
              I have found out that the MB is completely missing a 'Low frequency filter' component. It must have fallen off at some point.
              https://www.youtube.com/watch?v=rtgWFHdJqNY
              Anyone know where I can get one of these?
              EDIT: According to the service manual this component is an 'inductor', and from what I gather is the same component as the one next to it. Seems to be possible to buy this component online if you search for the part number (2703-004597).
              https://mega.nz/67a9bdf9-8fff-449f-95a6-f5937fdda781
              I guess if you have two S5s you could transplant one to the other (to the detriment of your donor S5 of course).
              If it is a filter I'm not sure why it would be a low pass filter (inductors behave as low pass filters don't they?) rather than a high pass filter, but at any rate this guy seems to have bridged the contacts and his speaker works: https://www.youtube.com/watch?v=zN_XHYNJ6v8
