HP Elitebook 850 G4 bios dump
    Hello guys , i need clean bios dump (without serial please) for 850 G4
    I have a few of these with this problem so it would be appreciated.
    thanks all
    i send a exemple (with bios password)
    Re: HP Elitebook 850 G4 bios dump
    thanks all
    try..
      Originally posted by peste View Post
      try..
      work fine !
      thanks Peste , you ROCK !
        hey ... I have an 840 g4, and it doesn't give me a picture, it turns on and turns on again, I think it's the bios .... I'll leave you here the bios .. I hope to help me, ...
        I tried the above but it does not give me an image, it turns on but after it turns off again and so on ...
        Thanks for the help!!
          I have the problem that it does not work, that is, the fan is going full, and it does not give video .... ram memory ok ...
          surely the bios is ..
          I have the original dump ..
          I have the 850 g4
            dump 16 mb 850 g4 recovry
              try..
                try..
                It does not work, the same does not give an image and it restarts and turns on... any other solution?
                  try bro
                  Kill the state in yourself and you will be free like a wind...
                    Originally posted by mazoot View Post
                    try bro
                    the same, as the previous one .. without image and restarts ...
                      if you have tried three, four different bios and the defect is the same, you may have another problem.
                        this is my 850 g4 motherboard ... 6050A2854301-MB-A01 850 G4,,, I don't think I have another problem ...
                          rty..
                            rty..
                            Not work ... Thanks for help ,
                              Can you fix my BIOS.
                              Symptoms: blinking CAPSLOCK and power button on and off after few seconds.
                              Tried with Intel Easy Clean Me, but still no picture.
                                Anyone please!
                                  it is fixed, got the main BIOS dump from other thread.
                                    I wouldn`t use Intel Easy Clean Me ,you make things worse using that tool.
                                      Hi Guys, Kindly ask for a password remove from the bios dump attached. Many thanks.
                                        Try RCUnlocker https://www.badcaps.net/forum/showthread.php?t=103526
