LG Flatron W2361V PSU Troubleshooting
    Hi everyone.
    I am trying to troubleshoot this computer screen which went black and won't power on after a power surge.
    I have measured the output voltages and there seems to be proper voltage pressence on the 5V outputs, there is no voltage on the 22V outputs and I am unsure of what I should be measuring on ADIM, BDIM, EN and OLP.
    There also doesn't seem to be any voltage on the backpanel outputs:
    I have already identified and replaced two bulging electrolytic capacitors, and there is voltage after the fuse.
    I am not sure how to proceed next. Any tips appreciated.
    Re: LG Flatron W2361V PSU Troubleshooting
    I just noticed that my picture links don't show up. Adding them here
    Pinout
    LCD panel outputs
    Board top view
      Make sure all the diodes and transistor are in good working condition and not shorted.
      Btw, did you checked the middle 8 pin chip?
        From what I can tell, If you have the +5v you should also have the +22v, both are supplied by the same transformer, so check the connections on the transformer and D201,D205.
        I would start by replacing C103, C105, they are very likely the main problem with the power supply
        I would replace all the electrolytic caps except for C101, it should be ok.
