HP Elitebook 840 schematic need
    Hp elitebook 840 g3 schematic needed
    Re: Hp elitebook 840 g3 schematic needed
    hi there i have same issue did you find schematic for this laptop ??
      Hp elitebook 840 g3
      PLEASE NEED SCHEMATIC OF HP ELITEBOOK 840 G3
      MB : 6050A2892401-MB-A01
        Schematic for this particular board doesn't seems available. Not even at sites which require a paid membership.
          I am looking schematic for HP 840 G3
          Hello
          I am looking for a schematic for HP 840 G3, I mean fragment from KBC to pins
          charging the battery.
          Board model: 6050A2728501-MB-A01
          PS. The problem is very slow charging of the 5% battery for 12 hours,
          battery excluded.
          Thank you and best regards Przemek
            I needed please
              HP Elitebook 840 shematic need
              hi
              HP Elitebook 840 G3 6050A2822301-MB-A01
              shematic need please help
                HP zbook 15u g3 schematic
                Hllo,
                i'm looking for schematic for HP zbook 15u g3 notebook, motherboard is 6050a2822301-mb-a01 i've searched the forum and all i could find is another thread with no responses for a elitebook 840 g3 that has the same code
                  Re: HP zbook 15u g3 schematic
                  There`s no schematic available yet .
                    Need schematics can someone help. thanks
                    6050A2892401-MB-A01
                      @atiq, Re-read post#2
                        Good day
                        i have laptop which is liquid spill. i fixed all voltage problem 3v and 5v all good motherboard powers on without cmos battery but donot powers on with power sw (2.6v comes in sw)...
                        can someone help me fix the problem. thanks
                          Originally posted by Atiq View Post
                          Good day
                          Please provide more information like Photos of the damaged areas caused by the liquid spill, what you have done already in more details, etc...
                          With your meter, check the voltage reading when you press down the power button, if the voltage drops to zero (0) or not.... I've seen cases where there's some kind of corrosion build up inside the Power button as a result of the liquid spill.
                          Also, if I'm correct, the KBC is NUVOTON NPCE586HA0MX. Try to get the datasheet of it or any other motherboard using that same KBC that has a schematic diagram/boardview so you can trace the Power switch pins to it
                            You need to check RTC section but open a new thread as this subgroup is for schematic request only.
                              need hp 840-g3 schematic
                                HP 840 G3 schematic needed
                                H igood day to all I have a shorted issue casue of water damge I want to check if you have any working schemtic?
                                6050A2892401-MB-A01 BOARD
                                  Does there happen to me a schematic available for this yet?
                                    3 long beep 2 short beep. iam change bios but not redy
                                    plees help
                                      Re: I am looking schematic for HP 840 G3 6050A2728501-MB-A01
                                      Hello
                                      Anyone have the diagram for HP Elitebook 840 G3 whit this board 6050A2728501-MB-A01, I need this very URGENT please
                                      Best Regards
                                      A. Neves
                                        Re: HP Elitebook 840 shematic need
                                        me too
