Hello everyone, as mentioned in the title im having problems with the screen circuitry. When i got the laptop it had a burnt hole in its screen cable and a few broken wires. It displayed on an external monitor without issue, still does. I ordered a replacement cable and popped it in today but still nothing.
I then looked around on the board to see if theres a fuse that couldve blown and found one. Not entirely sure if its a fuse, i mean its white ( ill be attacing pictures), but it doesnt have continuity. I looked to see where the connection went and from the left side of the fuse it beeps on a few wires on the screen connector. It also seems to be a ground which makes little sense to me (the left pad on the fuse). The same pads on the lcd connector are still grounds even with the fuse broken. I also saw that the left pad of the fuse is connected to a three pad mosfet(?) above it. I tested the mosfet and its also showing weird behaviour, unlike the other ones on the board. I even tried replacing it and at first it tested differently and after turning on and off the laptop it started behaving like the previous one- the ground pad and the one next to it short. And thats where my ideas stop, what could be the fried component and why has the fuse allowed them to fail?
The board id is DA0G7BMB6D0 rev d and i was unable to find a boardview.
Many thanks in advance to the members of this amazing forum, even if we dont figure it out.
EDIT: Even if that is a fuse i dont think it has anything to do with the display connector, i could be wrong still. The fuse is shorted to ground on one side and has no voltage going through it on the other.
