1000gb Seagate hdd help
    Hi guys i took out a 1000gb Seagate hdd from a Camara Video recorder and i connected it to my computer and booted up PC and still have the other installed win 10 hdd showing. Isn't that strange?means Desktop is running on a virtual HDD ,not on the connected HDD.?
    Re: 1000gb Seagate hdd help
    Check Disk Management and you'll probably see it.
    More than likely, it's an Ext2/3/4 filesystem that Windows doesn't recognize. Install Ext2Fsd and use that to mount the filesystem on the drive.
    WARNING: It's going to be mounted as an Ext2 filesystem (yes, you can mount an Ext3/4 filesystem as Ext2), which disables filesystem journaling. I advise mounting it read-only within the Ext2Fsd software.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      some dvr appliances use the udf filesystem meant for optical media like cd/dvds/blurays on their internal hard drives which they record to. if u still dont see any files, its probably a filesystem windows doesnt recognise or doesnt expect to be on a hard drive.
