Laptop has experienced some unfortunate liquid damage. It was immediately powered it off, and once I was able, disconnected the battery. There was some corrosion present near the vents, which was cleaned off using 91% isopropyl alcohol and a new soft-bristle tooth brush, but after thorough drying, the laptop wouldn't boot (no fans, no screen, nothing). I managed to get the laptop into DFU state to try and revive it, but experienced an error transitioning from DFU state to DFU state (error code 4042).
5v line (PP5V_G3S) is not coming up. I think I've narrowed it down to the U7800 not creating the P5VG3S_EN signal.
readings from U7800 (sym 1 of 4) are below:
PP3V3_G3H_SOCPMU: 3.4
PP1V1_SLPS2R: cycling between 0 - 1.1
PP3V3_G3H_RTC_X: 3.4
PP1V8_SLPS2R: cycling between 0 - 1.8
PP3V3_G3H_PMU_VINRTC_R: 3.4
PP3V3_S5: 0
PP3V3_AWAKE: cycling between 0 - 3.3
PMU_VPUMP: 5
LDO_RTC: 1.5
PP1V05_S0SW: 0
CPU_C10_GATE_L: 0
PMU_LDO3_OUT_R: 1.8
PP1V2_AWAKE: cycling between 0 - 1.2
PP3V0_G3H_RTC: cycling between 0 - 3.1
PP0V8_SLPS2R: 0.8
LDO_CORE: 1.59
Any pointers?
PP3V3_S5: 0
PMU_VPUMP: 5
LDO_RTC: 1.5
PP1V05_S0SW: 0
CPU_C10_GATE_L: 0
PMU_LDO3_OUT_R: 1.8
PP0V8_SLPS2R: 0.8
LDO_CORE: 1.59
Any pointers?
