BIOS Aspire A514-54G FH5AT LA-K092P.
    Hello
    i need acer a514-54g bios bin file, please help me as soon as possible
    thank you
    Re: BIOS Aspire A514-54G FH5AT LA-K092P.
    Aspire A514-54G
    Become a Badcaps supporter
    Thanks to all supporters.
      fh5at la-k092p REV 2.0
      need bios Aspire A514-54-579A
      mbd code - fh5at la-k092p REV 2.0
      no display
      i have attached my old file also
      snid - NXA2CAA0010431A5EB3400
        Re: fh5at la-k092p REV 2.0
        Aspire A514-54
          Hello sir, I need help. I need the bios firmware for
          Acer A514 54 36ZW
          Motherboard code: FH5AT LA K091P REV 2.0
          SPID: 207018
          Issue: Boot loop. Power on for 2seconds with no display then shutdown automatically.
          I also attached the old bios.
          Thank you so much in advance.
            Acer A514 54 36ZW
            SPID: 207018
            something is wrong wih your dump , try read again and re post
              try this one Nevermind, follow lapfix directions, your file is not complete.
                Hi sir, that's the only backup file I have. I already performed reset on the chip. Sorry, I'm totally a newbie here, please help.
                I have a downloaded bios from the acer website, but the file is in .exe. I tried extracting it and used the bin file but it's not working. Can you help me find the right bios file?
                I have downloaded it here:
                https://www.acer.com/us-en/support/d...lobal_download
                I have attached the downloaded file.
                  Your original file should be 16 MB or 16,384 KB in size. I have extracted a bios from the update, it does not have your DMI, that is the region where model, windows keys serial numbers are kept. Try it now, or wait until lapfix gives you a better solution.
                  Meanwhile look here: https://www.badcaps.net/forum/showthread.php?t=103526 and pay attention to section 4.2 DMI editing by hand- Acer
                    try Mazorca file , if not wirking try mine
                      Acer A514 54G 56QL
                      SPID: 207018
                      Issue: When I turn on blue light will light up for 1-2seconds then power off fan not even spinning.
                        Acer A514 54G 56QL
                        SPID: 207018
                        i don t think it s a bios issue ,post your thread here for more help : https://www.badcaps.net/forum/forumdisplay.php?f=23
                          Thank you.
                            Acer A514 54G 56QL
                            SPID: 207018
                            post the bios even if it is corrupted.
                              Acer Aspire A514-54-36ZW BIOS
                              I need help in recovering my laptop Acer Aspire A514-54-36ZW. Issue before was power loop (on and off for 2-3 seconds blank screen).
                              After trying to erase the BIOS, the loop disappears and it's totally dead. Power LED is working if I attached the battery but when battery is removed. Power LED is dead. I checked the board, it says FH5AT LA K091P REV. 2.0. I also the check the BIOS chip it says:
                              QH128AH1G
                              PPB49600 04
                              2041C
                              Hope it is the right chip.
                              Tried using the EZP2019 programmer but chip cannot be detected.
                              1. I need help in finding the right BIOS firmware.
                              2. How to properly place the programmer socket.
                              Please see attached images.
                              I'm totally a newbie here. Thank you in advance guys, appreciate all your help.
                                Re: BIOS Aspire A514-54 FH5AT LA-K093P.
                                BRO HELP ME CLEAN THIS BIOS,THANKS
                                  Hellow sir, I want help to clear ME my bios,
                                  Issue : Intermittent display and delayed to display
                                    Here's your Clean file, try it.
                                    all donations are welcome,
                                      Thank you sir
                                        i have also aspire vero no display issue..
                                        solve to this bin file thank you so much sir.
