Hello Experts
Need your help with SMPS repair for my LCD. The details as below.
1. Philips 40PFL4707/F7 Manufactured March 2012
2. SMPS Board BA21P6F01 01 1
3. SMPS board has a sticker that says A21P6MPW C 7219720
4. This is a 110v Mains Supply TV sold in USA
5. I imported this from USA into my country where we have 230V.
6. I have a simple winding transformer that converts 230v to 110v
For last few months, the TV was not in use and last week when I wanted to use it,I found it not powering up.
Primary suspect
1. Something went wrong inside the TV OR
2. Someone messed up the Main supply point and by mistake connected it to the 230V supply directly
I opened up the TV and found the fuse was blown. DMM test of Q601 ( K10A50D Toshiba MosFet) revealed that its Drain Source is shorted.
I did following tests
1. Desoldered one leg of all the HOT side diodes and all are Ok.
2. Did DMM continuity test of all the primary suspects on the HOT side and all are ok
3. No component is burnt
4. I had a spare IRF840 Mosfet. Its rated 500V and 8.5A. I replaced it for Q601 and the fuse got blown again. The MosFet was shorted again.
I looked at the shopjimmy.com repair kit for this TV model. All those components that he sells are perfect tested on my board.
Need help in various areas like
1. Any one has the schematic and service manual accessible for this model ?
2. Should I just insert a K10A50D and try once ? I feel it will blow up. I used IRF840 as its cheaper and easily available locally.
3. Do not solder Q601 and insert fuse and see if it blows up again ? That will show something else is wrong in Hot side.
4. Should I suspect the Gate circuitry ?
I am still not sure the root case of this issue. If its indeed supply of 230V then some component is blown up that appears hard to find.
I am attaching some images
Primary suspect
