Hp probook 640 g1 bios
    Re: This Bios has a password
    Originally posted by christian.ricard View Post
    Good morning, I have this bios that has a password, it was the only one that worked on this board, someone could remove it, thank you very much.
    Read post #161. Do NOT hijack unrealted threads.
      Re: Hp probook 640 g1 bios
      tks
        hi all , i have a HP ProBook 640 G1 with bios L77 admin password and i have tried the calculator but it didn t work .... Can anyone help me to read or remove the bios password using my dump file?
          rc unlocker
          Become a Badcaps supporter
          Thanks to all supporters.
            thanxxxxxxxxxxxxxxxxxx
              Re: Hp 640 g1 - 605a02566302-mb-a03
              hey all can any one unlock this dump
              thanks
              hp 650 g1
                thanks
                hp 650 g1
                https://www.badcaps.net/forum/showth...ht=rc+unlocker
                  Bios HP 640 G1 Clear ME
                  Hi, can someone please clear the me region of this bios as when powered receive mesage not in comitted state...Thanks.
                    Re: Bios HP 640 G1 Clear ME
                    MODEL : HP ProBook 640 G1
                    Serial Number : 5CG5073PF0
                    SKU : G5G37UC#ABA
                    FeatureByte : FBYTE#3X476J6S6b757H7M7Q7W7j7saBapaqauawbPbSce.Qn
                    BUILDID : #13WWCYAA601#SABA#DABA
                      Sorry for late reply, laptop power on but no display with this bios file.
                        Job done, i've clean the ME Region and now its working.
                          Hello, I also have a problem with the BIOS admin password on my HP 640 G1.
                          Can I read the BIOS file from the system with software or is it only possible with a programmer?
                            with a programmer.. read the bios and post the content here..
                            https://www.youtube.com/watch?v=DWWigscuQDY
                              I read the bios for a Probook G1 640 and tried the password removal tool which produced another BIOS. I flashed the bios directly to the chip using a CH341a programmer and the erase/verify/write/verify all returned successful.
                              Unfortunately, the laptop no longer boots. As soon as power is added, charger or battery, both power lights on the front begin to flash. Nothing on the display and the power button is on and doesn't respond to be pressed or long-pressed (assuming this is now bricked) and will end up being a de-soldering job. Additionally, CMOS battery is disconnected.
                              I have tried to put the original bios back on, (E/V/W/V) and all reports successful but the laptop is still in bricked state. I have attached the original bios with password on in the hopes that someone may be able to unlock and return it in a working state.
                              Much appreciated.
                                Your broplem here, but i don't know how to fix it.
                                  I was finally able to rectify the issue.
                                  I scrapped all the bios I had been given and used a stock A03 bios and flashed that. Verified ok and then power on the laptop. After a few seconds on a black screen and no flashing lights the laptop began to boot successfully into Windows.
                                  I have then completed a Bios update from HP through Windows which resulted in 2 bios updates, an update and then a secure update, and the device is still in working order.
                                  I have attached the Stock bios I used incase anyone else has this issue.
                                    Hello, here is my bios file, read out on the programmer.
                                    Please remove the admin password.
                                    Thanks in advance.
                                    Sebastian
                                      Thanks in advance.
                                      Sebastian
                                      Tool here : https://www.badcaps.net/forum/showth...ght=rcunlocker
                                        Re: Hp probook 640 g1 bios password remove
                                        Please help remove password
                                          read the post above..
