hp 240 G7
    hp 240 G7
    Hi. I need hp 240 g7 bios dump
    granGer2-6050A3155201-MB-A01 mainboard.
    thanks...
    Re: hp 240 G7
    thanks...
    Where's your serial number ?
    Where's your original corrupt bios file ?
    Become a Badcaps supporter
    Thanks to all supporters.
      Re: hp 240 G7
      sn 5CG9447W4N (CASE)
        Re: hp 240 G7
        HP 240 G7 Notebook PC
        Serial number : 5CG9447W4N
          Re: hp 240 G7
          thnaks......
            Re: hp 240 G7
            no display.not working
              Re: hp 240 G7
              There is another version of this model. If it also doesn't work then your problem is not bios related.
                Re: hp 240 G7
                The orj bios is corrupt. It works for 30 seconds. And then it shuts down after 5 seconds. then off.
                no power.
                  Re: hp 240 G7
                  No, with original from Hp home page , it will work if your problem is bios error.
                    Re: hp 240 G7
                    i change my eprom and try again dude
                      Re: hp 240 G7
                      The file from post #4 should work, if it doesn't, check your programmer or try to find some other problems.
                      I don't provide help for people using CH341A and a clip.
                        Re: hp 240 G7
                        hp 240 g7
                        sn:5CG9121MD5
                          Re: hp 240 G7
                          Originally posted by aqila View Post
                          hp 240 g7
                          sn:5CG9121MD5
                          What problem do you have??
                            Re: hp 240 G7
                            I need bios for 240 g7 sn:5CG1100MR0
                              Re: hp 240 G7
                              See if your bios chip is 8MB or 16MB, perhaps my hints will be useful.
                              all donations are welcome,
                                Re: hp 240 G7
                                Serial number 5CG1100MR0
                                https://parts.hp.com
                                HP 240G7 i3-1005G1 14 4GB/1T PC
                                i3-1005G1 10th gen
                                Open each bios with ME Analyzer and look at the chipset support.It can`t be 08498 either as its KBP kaby lake with ME 11 firmware.
                                  Re: hp 240 G7
                                  i3-1005G1 10th gen
                                  So, why when I search by the model number, it gives me 7 different CPUs!
                                  https://support.hp.com/ph-en/document/c06168317
                                    Re: hp 240 G7
                                    Thats the way HP bundle bios updates,for different models in the same updater or for the same model with different SKU`s, crazy i know.
                                      Hi guys.
                                      Someone can Fix this corruped BIOS? (no screen after replace U66310 burned) , thanks in advance.
                                      Serial Number: 5cg9455lrt
                                      Product Number: 6GJ38LT
                                      Description: HP 240 G7
                                      Core i5-8265U
                                      GRANGER2-6050A3155201-MB-A01(A1)
