Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 01-20-2018, 06:32 PM   #1
m4a2t0t
City & State: Arizona
My Country: USA
I'm a: Knowledge Seeker
Default A1286 No backlight
I have a Macbook Pro A1286 with a core i5 and it has no backlight after reballing the GPU.
The laptop would not display any high resolution content. After clicking on the username the laptop would start loading and then display a grey screen. It would not load recovery, internet recovery or any utility.
The laptop will now login and displays content fine but it has no backlight.
Any suggestions on what to look at first? Anyone have schematics or board viewer?
I've tried re-plugging all the cables, SMC reset and tried the brightness buttons. Anything I might be overlooking?
EDIT: FOund board viewer https://www.badcaps.net/forum/showthread.php?t=44413 . Will check Backlight filter.
m4a2t0t is offline   Reply With Quote
Old 01-21-2018, 12:40 AM   #2
audiomodder
City & State: California
My Country: USA
Default Re: A1286 No backlight
Search 820-2915-A schems and boardview in an internet search. you will come up with stuff.
Did you seriously attempt a GPU reball without even the schematic? Wow....gutsy.
Once you get the schem, check out the backlight driver circuit and look at the EN pin. Also, the CLK and DATA (coming from the GPU) lines with 100k pullups to the LVDS are important and will keep your internal display from working if they are shorted or missing.
There is also a small backlight fuse which is always worth checking. But get on those schematics first.
audiomodder is offline   Reply With Quote
Old 01-21-2018, 07:09 AM   #3
alihomee
City & State: kuala lampur
My Country: pakistan
u can find fuse and light ic near the fan connector
alihomee is offline   Reply With Quote
Old 01-21-2018, 02:11 PM   #4
m4a2t0t
My Country: USA
Thanks. The fuse is open. Guess I should start at the beginning of the circuit instead of the end.
Old 01-21-2018, 11:13 PM   #5
audiomodder
My Country: USA
yep, check the EN stuff first, then the IC output, then both sides of fuse. If all is OK only THEN replace the fuse.
Old 11-21-2019, 05:31 PM   #6
tblam
City & State: Montreal
My Country: Canada
Line Voltage: 120VAC 60Hz
Hello! (I am new to forums so I hope I'm not doing anything wrong writting on someone else's post!)
I also have this board, no GPU reballed just the original thing. Fuse is 12.53V on each side and I have 3.3V on BKLT_RST but 0V on BKLT_EN. So I guess I have to change IC U9600 but where can I see if there is power going to it first? I don't want to unsolder that kind of thing for the first time and find out later that it was not the problem xD
Thanks for your help!
tblam is offline   Reply With Quote
Old 11-22-2019, 08:47 AM   #7
piernov
Moderator
City & State: Valbonne, 06
My Country: France
820-2915 = dead GPU.
__________________
OpenBoardview http://openboardview.org | IRC #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
