Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 11-22-2019, 02:49 PM   #1
bfordz
City & State: G.R.,Mich
My Country: USA
Line Voltage: 120vac 60hz
I'm a: Knowledge Seeker
Default Dell F177FPE monitor, won't power on
I've got a Dell F177FPE that went dead, it won't power on.
There's no power "on" light or anything.
I took it apart and the caps all 'look' good but they're all cheap Su'scon's or Teapo's.
While doing some basic tests of the board I found a Ceramic capacitor that shows open with the ohm meter, so I'm hoping that's the cause of my no power up problems. I included pics of the failed cap and it's location on the board.
My question / problem is I've never replaced or dealt with these type of capacitors so I want to know if I'm reading it correctly and my choice of replacement is correct. (based on what I've read)
The original is a JNC JN332M 250v and I'm not sure what the 440 x1 and 250 x2 means.
I've picked out a Murata Electronics DE1E3KX332MA4BN01F replacement.
I'm also going to replace all the Alum Elect Caps while I'm in there.
If there is anything else you notice, I'm open to suggestions.
bfordz is offline   Reply With Quote
Old 11-22-2019, 03:15 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Dell F177FPE monitor, won't power on
That is a snubber cap is supposed to read open. If it would have failed, you would see it. Since you don’t even have a stby led, probably the stby power rail that is always on is not working, or there is no AC going to the bridge rectifier. So check if you have about 170VDC on that main filter cap. Also the PFC needs to work (roughly 380VDC on the main filter cap) in order for the backlights to work.
CapLeaker is offline   Reply With Quote
Old 11-22-2019, 03:41 PM   #3
bfordz
My Country: USA
Well, that shows how much I know! Very little when it comes down to the real nitty gritty.
Most of my boards have all shown the issues, when it comes down to the actual 'what needs to be tested and the results' is where I get a bit lost.
When you say 'main filter cap' which one are you referring to?
Old 11-22-2019, 04:01 PM   #4
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Why don't you start by checking if the fuse is good or if you have any voltage across the main filter C854 (the blue 100f/450v) capacitor. If you have 160vdc across the main filter, check the resistance of R852, it should be 0.2Ω
That cap you have circled has nothing to do with the operation of the power supply, it is a safety cap that connects the hot and cold grounds.
R_J is offline   Reply With Quote
Old 11-22-2019, 04:15 PM   #5
bfordz
My Country: USA
The fuse is good and the R852 is 0.2ohms. I'll check voltage now.
Old 11-22-2019, 04:25 PM   #6
bfordz
My Country: USA
Main filter - 171.2vdc
R852 - 0.4ohms
Old 11-22-2019, 04:42 PM   #7
R_J
City & State: ☻
My Country: Canada
D854 is the secondary dual diode, check the voltage across C862
If you have your +12 volts then the primary circuit is working, Check the voltage on U801 and U802, I don't know what there voltage should be, you may need to post the part numbers, I suspect one should output either +5v or +3.3v
Near the LVDS cable is a fet Q501, check if there is voltage on S and D, You also check the voltage on the Gate and see if changes when the power button is pressed.
You can also follow the wire from the power switch and see if there is any voltage on it and does it change when the button is pushed? If the microprocessor and eeprom U402 are getting VCC voltage you may have a corrupt eeprom causing the monitor to not turn on.
Old 11-22-2019, 04:56 PM   #8
bfordz
My Country: USA
12.07vdc
Old 11-22-2019, 05:39 PM   #9
bfordz
My Country: USA
U802
1 - 0.0v
2 - .433v
3 - 1.25v
4 - .433
U801 (no numbers but using same as 802)
1 - 0.0v
2 - not connected
3 - 5.20v
4 - 1.25v
that's checking voltage at each terminal not across terminals.
Old 11-22-2019, 05:49 PM   #10
R_J
City & State: ☻
My Country: Canada
You can use some alcohol to clean the top of the ic so you can readthe numbers, or try looking at an angle, you may be able to read them, but the voltages don't look good.
The microprocessor operates from 3.3 volts, one of those regulators should be a 3.3 volt regulator
Without the regulator ic numbers it is hard to tell what the input and ouput voltages should be. I can see numbers on the ic's in your picture, what are the numbers?
Old 11-22-2019, 05:49 PM   #11
bfordz
My Country: USA
here's a diagram
Old 11-22-2019, 06:35 PM   #12
bfordz
My Country: USA
U801
a1
asiii7r-33
bo635 26
u802
ac 6i8l
17-18l
Old 11-22-2019, 06:49 PM   #13
R_J
City & State: ☻
My Country: Canada
Those numbers can't be correct, Could it be a AS1117-33 If it is, it will be a 3.3 volt regulator
IC801 has +5volts on its input and only 1.25v on its output (it should be 3.3v) so something is loading it down
Also are you sure your model number is correct? I can't find it listed anywhere
Old 11-22-2019, 06:51 PM   #14
bfordz
My Country: USA
It is AS1117-33 can't tell if they're 1's or I's.
Old 11-22-2019, 07:07 PM   #15
bfordz
My Country: USA
Long week...E177FPf (sorry)
Old 11-22-2019, 07:43 PM   #16
R_J
City & State: ☻
My Country: Canada
It looks like U851 is a 5 volt buck regulator, pin 1 is the input (12v), pin 2 is the output (5v), It feeds U801 3.3 volt regulator, pin 3 is the input (5v) pin 2 is the output which is low.
I suspect U802 is a 1.8volt regulator so something could be shorted on its output which is also loading down its input.
I suspect the number could be ams1117-18
Old 11-22-2019, 07:51 PM   #17
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
ah, so there is power to the main filter...
Looks like that U801 is feeding U802 power. So U801 must be bad or getting loaded down.
Old 11-25-2019, 09:28 AM   #18
bfordz
My Country: USA
I included a better pic of U801 for reference.
For U851 here are the actual v readings:
1 - 12.0vdc
2 - 5.2vdc
3 - 0.0vdc
4 - 1.25vdc
5 - 0.0vdc
sorry for the delay, I was away from my computer this weekend.
Old 11-27-2019, 03:02 PM   #19
bfordz
My Country: USA
RJ, thank you for your help and input. Also, the regulator lessons and how they function.
It also encouraged me to look a little further to learn some more besides just replacing "caps".
Capleaker, thank you for the 'snubber cap' information, I would have replaced it but then that's why I inquired here first. I actually 'thought' I had something when it tested open. Live and learn!
Old 12-01-2019, 11:42 AM   #20
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
I’d replace that 3.3v regulator and see what happens.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
