Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Soyo - Shuttle - Supermicro
Old 01-29-2013, 04:46 AM   #1
Nomad
Default Finally found them! Shuttle SG31G2S
Been pretty sure there's problems with my Shuttle for more than a year now, but visual inspection has lead nowhere, nearly all the caps are solid type. But now that I've completely dismantled it, I could clearly see three 1800uF radial caps labeled TK. All bulging, and a quick search on those will show many failures in other boards. Will get some caps and swap them out.
Nomad is offline   Reply With Quote
Old 01-31-2013, 06:17 PM   #2
Lance Thornton
City & State: Sunny Florida, USA
Default Re: Finally found them! Shuttle SG31G2S
Welcome Nomad,
I've had to replace the same 3 capacitors in 3 seperate shuttles. TK are known as "Terrible Kapacitators" which is a polite understatement. I believe that your Shuttle should be fine after replacement, and good luck!
Lance Thornton is offline   Reply With Quote
Old 05-06-2013, 06:31 PM   #3
Sudos
City & State: Linden, NJ
My Country: United States
Line Voltage: 120VAC 60Hz
I just acquired 4 SG31G2's for free. all had problems marked on them, and all had a helping of 1 to all 3 of the 6.3 1800's bulging.
pretty much harvested the capacitors needed off of a donor board full of Rubycons (not good practice, I know.) and recapped them all, didn't bother leaving the non-bulging ones in there. Viola, all 4 are running strong just like that. I left them each on for 3 days straight under heavy load and they haven't had any issues. one even went cross-country already and now has an E8200 and an 8800GT stuffed in it.
Pic Related, you can see here the marked off bulging ones.
Sudos is offline   Reply With Quote
Old 05-10-2013, 05:22 PM   #4
Lance Thornton
Thumbs up Re: Finally found them! Shuttle SG31G2S
It's amazing to me that those three caps can trash these fine little boxes. Good find on your part!
Old 05-10-2013, 11:11 PM   #5
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
You'd think they would stop using bad caps by now. But I guess Shuttle (or whoever is manufacturing their boards) just doesn't want/care to.
That's sad. Bad caps can indeed trash the motherboard - sometimes irreversibly like on my Shuttle SB83 motherboard.
Old 05-29-2013, 07:57 PM   #6
Lance Thornton
We just got a new Shuttle in for a coral reef imaging project. I'm not sure of the model number. It has all polymer caps on the motherboard. I'm not sure about the power supply. Maybe Shuttle is getting their act together.
