Old 01-25-2019, 01:43 AM   #21
misteeka
City & State: richmond
My Country: canada
Default Re: Dell U2413 turning off
Hi djatila666,
I just bought a refurbished unit of this monitor and have the same problem. I'm glad I found your post and this forum. Is your monitor still stable now more than 2 months after your last post?
If so, I'm tempted to try the same fix (versus returning my unit to the dealer and dealing with shipping etc).
What was the process involved in applying new thermal paste to K15A60U? Is there a recommended method to remove the heatsink (is there any best practice I should be aware of)?
And is adding the radiator to LD7904jgp7 as straightforward as it sounds? I can look up how to do this, I assume also with some application of thermal paste etc.
Thanks in advance for any help and for your contribution to this thread!
misteeka is offline   Reply With Quote
Old 02-01-2019, 05:58 PM   #22
djatila666
City & State: malaga
My Country: Spain
Hi misteeka
My monitor is working good. Look the image.
That is my repair.
djatila666 is offline   Reply With Quote
Old 06-12-2019, 10:39 PM   #23
gamexciter
City & State: hanoi
My Country: vietnam
I got the same problem.
- Standby power (5V) still on
- PS1 (24V): 0V
Already replaced some following components: 03 schottky diodes (SRF 30-10) + 1 opto coupler at Main Switched PS; IC LD7904JGPN; MOSFET K15A60D at FPC area; 02 MOSFETs K10A60D closely to the main transformer. Nothing changes.
When used a laptop CPU cooling fan and directed the air flow to the main switched PS area, the screen turned on in 3 seconds.
I used a meter to check the value of components around the PFC and main switched PS areas. All components seem to be still in good condition.
Thanks for any help
gamexciter is offline   Reply With Quote
Old 07-17-2019, 06:54 PM   #24
slashgeegee
City & State: manila
My Country: philippines
check the capacitor if theres a leakage
slashgeegee is offline   Reply With Quote
Old 10-28-2019, 01:34 AM   #25
gaijin4life
City & State: California
- PS1 (24V): 0V
Thanks for any help
Q971 and Q971 are likely the problem. Gated thyristors that have become too sensistive.
gaijin4life is offline   Reply With Quote
Old 10-28-2019, 06:07 PM   #26
gaijin4life
Meant to say Q971 and Q972. Won't let me edit...
Old 11-15-2019, 10:58 PM   #27
gaijin4life
So replacing the two thyristors are the answer for this problem. Q971 and Q972. Unforunately the original MCR part had a non-standard arrangement of Gate, Anode, Cathode (K) leads, and there are none I could find with the correct order, so you MUST bend the pins to have the right one go to the correct hole on the board, changing the Littlefuse Thyristor from KGA pin order to GAK order to match the original part - you CANNOT use the default arrangement.
The replacement part you want is Littelfuse S4X8ES2, and mouser.com has them for a 45 cents each - the $7.99 shipping will be the most expensive part of this. I ordered 4 since they were so cheap so I had spares in case I accidentally broke a pin in the bending.
The data sheet for the part is here: https://www.mouser.com/datasheet/2/2...pdf-319336.pdf
To open the case on your Dell U2413, I highly recommend the ifixit kit with the guitar pick things (or actual guitar picks). They get the case open without marring it.
I’ve attached a few pictures showing where the parts are on the power supply board in the monitor and also how to bend the pins of the replacement thyristor so it has them in the correct order when you solder it onto the board. This will stick up a lot higher than the original due to the bending (so you don’t have any of the legs touch - DO NOT HAVE THEM TOUCHING EACH OTHER AT ANY POINT), but that’s no problem.
Thank you Dell for cheaping out on parts, cutting another corner that your customers have to figure out to avoid throwing a perfectly good monitor away.
Old 01-12-2020, 08:48 AM   #28
qwec01
City & State: Beijing
My Country: China
Line Voltage: 220VAc 50HZ
I have similar problem, black screen, backlight off, power led off, 3 USB ports have 5V, the one with lightning sign dosen't, and I can't turn it on, after 3mins, it will turn on automaticaly, looks like an overheat problem.
The monitor will turn off quicker when it's 100% brightness compared to 30%, when the monitor shuts down, I measured standby voltage, it's 5.0-5.2V and not steady, the ps-on signal is below 3.3V and jumping around, the wierd thing is the 24V is present and steady.
I don't know if replacing Q971 and Q972 will work, need help, Thanks!
qwec01 is offline   Reply With Quote
Old 06-23-2020, 04:53 PM   #29
ctgs
City & State: Toronto
My Country: Canada
I had pretty much the same issue. The screen would work for a bit, then power off (with the power led blinking) but not responsive. I'd have to wait between 2 and 10 minutes before I could power it on again and this would just repeat after a while.
Replacing Q971 and Q972 fixed it for me. Just remember when disassembling start with taking the bezel off. Using a multi-meter to check for shorted pins before putting everything back together.
ctgs is offline   Reply With Quote
Old 06-24-2020, 06:50 AM   #30
dotcrawl
City & State: Here
My Country: UK
I'm having the same issue (along with a slight pink tint, but that's another story). I assume the aforementioned Thyristor is the answer, but I can't find a UK supplier for it, and I'd rather not pay £12 to import a single Thyristor.
In looking for a substitute from a local supplier, is there anything I need to look for/avoid, or will anything work (as long as the specs are identical, and the brand is reputable)?
dotcrawl is offline   Reply With Quote
Old 08-01-2020, 06:32 AM   #31
dotcrawl
City & State: Here
My Country: UK
For what it's worth I'll reply to myself to state I eventually used a BT169D, due to its availability, price, and slightly higher junction temperature. Bending its pins from K-G-A to G-A-K required routing the K pin across the other 2, and heat shrink was used to ensure it didn't make contact.
So far it appears to have worked, although due to the nature of the circuit I'll only know if the gate isn't opened in the (unlikely) event of overvoltage. Fingers crossed.
Old 09-09-2020, 02:41 PM   #32
ej4
City & State: Texas
I have two Dell U2413f (rev A01) working fine. Picked up a 3rd from eBay b/c overkill, why not. Well it powers off after about 5 minutes. Cycle power, shuts down after 90 seconds. Cycle power, shuts down after 15 seconds. So I'm thinking it's the same issue documented here. Something is getting too hot.
The eBay seller offered a full refund. I'm tempted to ask if I can keep it if they refund me perhaps all but shipping. If I can keep it for super cheap I'll give the repair/mod a try. If they will only refund with a return, then obviously I won't tinker.
If I am reading this correctly, I see two possible solutions documented here?
@djatila666 had one solution
Originally Posted by djatila666 View Post
It has been running for two days without turning off. I put new thermal paste on the K15A60U and I attached a radiator to the LD7904jgp7
@gaijin4life has another solution
So replacing the two thyristors are the answer for this problem. Q971 and Q972....
Are these both required? Complimentary? Different/unrelated?
I'm entirely unfamiliar with soldering so to me the heatsink approach is appealing if it is a fix.
ej4 is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2021
